Could we have purchased a bad trailer?
Last activity 2007-05-01 4:18 PM
8 replies, 4505 views
nolefan
Reg. Jun 2006
Posted 2007-04-30 9:03 PM (#60207)
Subject: Could we have purchased a bad trailer?
We recently purchased a 2 horse BP alum trailer from a dealer recently.  We found out later that it has been used to haul hay to the pastures.
It seems to pull OK but should we be concerned that we bought a bad trailer?
Thanks
Terri
Posted 2007-04-30 9:16 PM (#60209 - in reply to #60207)
Subject: RE: Could we have purchased a bad trailer?
200050010010010025
Why would you be worried?  Most of the people I know use their horse trailers to haul hay.  As long as they weren't doing 60mph in the pasture the most that would happen is a flat tire.
nolefan
Reg. Jun 2006
Posted 2007-04-30 9:22 PM (#60210 - in reply to #60207)
Thanks for your reply.  Just wanted to make sure that we should not be concerned.  We read a previous post about a pulling a trailer over dirt or bumpy roads how that can damage the frame.
Posted 2007-04-30 9:52 PM (#60212 - in reply to #60210)
I pull my trailers over all kinds of dirt and gravel roads. My trailers have held up just fine.
I've seen lots of folks out picking up bales of hay in their horse trailers. Most hay fields are smoother than the dirt roads I drive.
Posted 2007-04-30 10:39 PM (#60216 - in reply to #60212)
1000500100100100252525
Everything should be fine as everybode else said the dirt road not bad have you see some of the paved road around?
crowleysridgegirl
Reg. Apr 2005
Posted 2007-04-30 11:30 PM (#60222 - in reply to #60207)
2000500100
We once had a 4H BP WW trailer that we moved household belongings in.I've moved a lot of stuff in my trailer,tall furniture pieces,mattresses,ect.I'm glad that I had them.
Our gravel roads are like washboards in places.Altho I don't like having to pull our LQ trailer over them because of all of the electronic things inside,we don't blare out fast,and our trailers have held up fine.We hauled a lot of hay in our stock trailers and 2H both when it looked like rain might be on the way.
Long as your trailer doesn't have major rust or corrosion,I wouldn't worry about it  at all.
Terri
Posted 2007-05-01 12:07 AM (#60224 - in reply to #60210)
200050010010010025
They must have been drag racing then.  I can't imagine any pasture or dirt/gravel road taken at a safe speed that would ruin the frame of a trailer/truck.
Posted 2007-05-01 7:40 AM (#60230 - in reply to #60207)
Originally written by nolefan on 2007-04-30 8:03 PM
Thanks
Set your mind at ease ... It would be hard to  load a 2H BP trailer with hay weighing more than a couple of horses.   Even if they got 40+ bales aboard, the weight is evenly spread unlike a horse.  Any damage from driving in a field is readily apparent.
bechack
Reg. Mar 2006
Posted 2007-05-01 4:18 PM (#60264 - in reply to #60207)
The only thing I would worry about would be bent axels.  Watch for uneven tire wear.  But basically, I wouldn't worry about it either....
