trailer ramp install myself?
Last activity 2007-04-29 7:29 PM
6 replies, 4738 views
sinful
Posted 2007-04-28 10:27 AM (#60100)
Subject: trailer ramp install myself?
I have a featherlite 3 horse that I just bought a ramp for.  How difficult is it to install myself?  Has anyone tried this?   Doesn't it just bolt on where the bumper was and a few holes drilled for the latches.
Reg
Posted 2007-04-28 12:19 PM (#60102 - in reply to #60100)
Subject: RE: trailer ramp install myself?
2000500100252525
Originally written by sinful on 2007-04-28 10:27 AM
For some odd reason I would have expected installation instructions to have been included.
Anyway, the hardest part might be loading the spring(s).
Other than that I'd assume it is a simple matter of lining it up and bolting it on - ?
Does it have sets of holes that look as if they will line up with the ones the bumper uses ?
If so - GO !
If not - stop.
Scratch head, consult installation instructions, contact factory, etc.
sinful
Posted 2007-04-28 6:15 PM (#60115 - in reply to #60100)
Reg.  Someone else bought the ramp new, now don't want it.  So I got a deal.  I could always have featherlite do the work.  Just thought I'd save myself high dollar labor charges.  I never thought about loading the springs.   That could be interesting...to say the least.   Better call the dealer and get the low down from him.
BigT
Posted 2007-04-28 10:07 PM (#60118 - in reply to #60100)
When the ramp is in the up position, there is little or no tension on the springs. Once you get the attachments installed on the trailer, and the latches, you support the ramp in the up position, then insert the rod through the first attachment then a sping etc until done.
Reg
Posted 2007-04-29 7:08 AM (#60124 - in reply to #60118)
2000500100252525
Originally written by BigT on 2007-04-28 10:07 PM
That only works for the "spring in hinge" type, which I agree is most common.
sinful
Posted 2007-04-29 10:27 AM (#60134 - in reply to #60118)
Its probably not that difficult.  I think I'll try it myself.  If I can't get it, I'm sure the dealer will. Thanks Guy's
Reg
Posted 2007-04-29 7:29 PM (#60154 - in reply to #60100)
2000500100252525
Even the "leaf spring underneath" type probably isn't THAT difficult to pre-load.
I was sort of thinking about this thread when I caught sight of that type at a show today.
Once assembled it can probably be lifted in with a floor jack and then the last bolt or pivot put in.
