Proportional Controllers
Last activity 2007-04-27 8:24 AM
7 replies, 3624 views
10Ha.Wood
Reg. Jun 2006
Posted 2007-04-26 11:53 AM (#60005)
Subject: Proportional Controllers
I'm now entering my second season pulling my 3H gooseneck. I'm getting a little frustrated with my timed brake controller. If I go ahead and purchase a new controller, can I just swap them, or am I going to have to spend another hour upside-down under the dash splicing wires? In other works, are the connectors on the controllers themselves standardized? Are they at least standardized if I stick with the same manufacturer? (Reese)
Kay
Posted 2007-04-26 12:24 PM (#60012 - in reply to #60005)
Subject: RE: Proportional Controllers
50025
If your present controller is wired into a brake control harness, it is plugged in under the dash.  Unplug it, cut the old controller off of it, wire the new controller to the harness (you can do this standing erect), and plug it back in.
If you don't have a pre wired vehicle, you will be standing on your head under the dash.  Good luck.
jdzaharia
Reg. Apr 2006
Posted 2007-04-26 12:48 PM (#60016 - in reply to #60005)
1001001001002525
Okay, pretend we do not have a pre-wired pickup. Are the four wires on my Tekonsha the same four wires that are on a (insert another brand here)?
10Ha.Wood
Reg. Jun 2006
Posted 2007-04-26 12:49 PM (#60017 - in reply to #60005)
kay, you got a good point there. I'll only have to play like a bat to cut the tie wraps and pull the harness out from where I went to some effort to route it out of the way of the pedals etc. Then do it all over again. I'd still rather pull the connector from the old controller and plug in the new one. And, oh yeah, it would be nice if the mounting bracket is compatible as well.... sigh. I'm probably SOL
Edited by 10Ha.Wood 2007-04-26 12:51 PM
chadsalt
Posted 2007-04-26 7:51 PM (#60038 - in reply to #60005)
1000100100100100
you made it to a "second season" with a timed controler? i dont see how you made it past the "second stop", imho those POS ought to be illegal.
Reg
Posted 2007-04-27 5:41 AM (#60052 - in reply to #60016)
2000500100252525
Originally written by jdzaharia on 2007-04-26 12:48 PM
Yes,
although the wire colors and the physical connector might be different.
jdzaharia
Reg. Apr 2006
Posted 2007-04-27 8:12 AM (#60054 - in reply to #60052)
1001001001002525
Thanks Reg.
My dad says his brake controller has a cable that hooks to the brake pedal somehow and proportions the brakes that way. Has anybody heard of that? Are they any good?
10Ha.Wood
Reg. Jun 2006
Posted 2007-04-27 8:24 AM (#60055 - in reply to #60038)
Originally written by chadsalt on 2007-04-26 8:51 PM
Heh, Yeah, I decided I can't put up with it any more when I realized I have the ramp set at the slowest setting and keep the 'peak' low enough that the truck is doing most of the braking. What is the point of even having the thing?!?
What 'ought' to be illegal is the prices! The accelerometers used to be expensive, but like all things silicon, they are practically free today. $300 CAD is outrageous for something that can't cost more than the $70 model to make.
Edited by 10Ha.Wood 2007-04-27 8:27 AM
