Tankless water heater
Last activity 2007-04-25 3:40 PM
4 replies, 4007 views
riddenhardputawaywet
Posted 2007-04-25 1:45 AM (#59910)
Subject: Tankless water heater
Anyone have experience with one of these?
  Marey RV LPG Tankless water heater
 See ebay item# 330110332099
Posted 2007-04-25 6:04 AM (#59914 - in reply to #59910)
Subject: RE: Tankless water heater
I've never heard of that brand of tankless water heaters.
In general tankless water heaters are lousy for homes but acceptable for RV's, cabins etc.
The main reason being the FLow Restrictors most require. You have to slow the water flow down in order for it to heat up as it passes through the heater.  People in their homes want to FEEL the water pressure blasting out of their shower head, not dribbling out.
In a RV, Water conservation is the key, so most owners will accept very low pressure as an acceptable substitute for no having to drain a tank after they get done to prevent freezing, and since most only carry  a limited abmount of water to begin with.
The Ebay item says it for a house, a similar item says its for an RV.  I would suggest you purchase that one in place of the whole house unit. It's probably more compact to fit inside a RV.
These units are really cheap in comparison to the units I see people trying to use in homes. The Bosch, Rinnai and other whole house units retail for $1000 per unit. So I'd be skeptical of something claiming to the same work for $150.
goethetrail
Reg. Oct 2006
Posted 2007-04-25 7:29 AM (#59920 - in reply to #59914)
I have tankless in my home...it is the size of a phone book and it was $600.  Works fine, pressure is great and we have well water.  We love it; ours is electric. Our neighbor has a smaller one in her barn to wash the horses with.  The US is one of the very few countries that cooks water all day long in conventional water heaters.
equiteacher
Reg. Mar 2007
Posted 2007-04-25 10:11 AM (#59925 - in reply to #59910)
 - Slightly
We have a SEISCO electric water heater in our house for four years now, and it works great except for opening the big spigot to out jacuzzi tub all the way. Have to keep it at about half open. Otherwise can run showers in master bath room and both guest's baths at the same time and never run out of hot H2O.
At first we had a great deal of trouble with the micro-switches failing, but they replaced all of them with a new type and have had no problems for a long time now.
greyhorse
Reg. Nov 2005
Posted 2007-04-25 3:40 PM (#59952 - in reply to #59910)
I would go this route if I ever have to replace my 10 gallon tank. http://www.gaswaterheaters.com/boatsandrvwaterheaters/RV500/
