Needing advice
Last activity 2007-04-19 6:32 PM
17 replies, 5705 views
GtSaucke
Reg. Apr 2007
Posted 2007-04-17 4:43 PM (#59473)
Subject: Needing advice
What is the largest and safest enclosed trailer that can be hauled using a 1995 Ford Taurus? Going a distance from WI to OR. This will not be for transporting animals, more just personal belongings.Opinions?Thanks
Edited by GtSaucke 2007-04-17 4:46 PM
Reg
Posted 2007-04-17 4:59 PM (#59475 - in reply to #59473)
Subject: RE: Needing advice
2000500100252525
Originally written by GtSaucke on 2007-04-17 4:43 PM
Hi and Welcome.
The RIGHT answer is to check with your owner's manual and if you don't have that go to the Ford web site and look it up.
My informal guess is that your car is unlikely to be rated any higher than 2,000 lbs.
Be careful with those little U-haul rental trailers, they can take a lot more weight than most cars can (safely) pull, steer or stop.
N2ridin
Posted 2007-04-17 5:38 PM (#59477 - in reply to #59473)
50010025
If you're thinking about pulling that person's horse trailer with a Ford Taurus.  think again.  Let me know the direction you'll be traveling, so I can stay off the road
Reg
Posted 2007-04-17 5:51 PM (#59478 - in reply to #59477)
2000500100252525
Originally written by N2ridin on 2007-04-17 5:38 PM
You REALLY need to read before replying.
RoperChick
Reg. Dec 2005
Posted 2007-04-17 6:26 PM (#59483 - in reply to #59473)
My post is in response to this thread too:
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=6979&posts=2The
The empty trailer is probably already above the maximum tow rating for a Ford Taurus.
Edited by RoperChick 2007-04-17 6:40 PM
crowleysridgegirl
Reg. Apr 2005
Posted 2007-04-17 6:30 PM (#59484 - in reply to #59477)
2000500100
Saw your post and I know what you meant.I saw it too.It's in the next thread,"Can you haul my trailer from MI to WA?" You read right,gal.
Edited by crowleysridgegirl 2007-04-17 6:32 PM
RoperChick
Reg. Dec 2005
Posted 2007-04-17 6:40 PM (#59485 - in reply to #59478)
Originally written by Reg on 2007-04-17 3:51 PM
I knew what N2Ridin was referring to also, she read it right
Edited by RoperChick 2007-04-17 6:41 PM
GtSaucke
Reg. Apr 2007
Posted 2007-04-17 6:48 PM (#59487 - in reply to #59473)
Ok, thanks to all that responded, but I replied to the other post about hauling that persons trailer for him before I started my own. Lemme just clarify here. My brother is moving from WI to OR to live with me, and the cost for me to move here two years ago using american van lines was about $3k for a full move like a house worth of belongings, my brother is moving a very limited amount, maybe one bedrooms worth, but more than he can fit into his car. So he needs to find the "largest" & "safest" trailer he can tow with his 95 Ford Taurus. Now with all that said does anyone have any opinions. Brands, styles, cost? These are more what i need, I look forward to your educated and very welcomed knowledge on the subject of trailers. Thanks again.
RoperChick
Reg. Dec 2005
Posted 2007-04-17 7:09 PM (#59488 - in reply to #59473)
The first step in deciding what size trailer the car can safely pull is to find out what the GCVWR (Gross Combined Vehicle Weight Rating) is.   I'm imagining that it won't be capable of pulling a very big trailer.  You might try renting a truck from Interstate truck rental.  They have full sized trucks set up for towing. here's their website: http://www.goitr.com/
A word of caution, my husband and I discovered not too long ago that houshold items are much heavier than expected.  We had to quickly move my husband's sister out of the house she had been renting because, due to a landslide, it had been red tagged.  We had just a few hours to get a housefull of stuff out.  We used our three horse trailer for the move.  That trailer after it was loaded was far heavier than it has ever been for one of our fully loaded cross country trips with our horses.
Good luck, I hope the move goes well. :)
Reg
Posted 2007-04-17 7:10 PM (#59489 - in reply to #59473)
2000500100252525
The title of neither thread is;
"Disjoint threads, guess which other one I'm replying to in THIS one".
The answer is still probably 2,000 lbs and MOST horse trailers weigh more than that empty.
Posted 2007-04-17 9:21 PM (#59499 - in reply to #59487)
Originally written by GtSaucke on 2007-04-17 7:48 PM
He needs to rent a U-haul truck for his belongings with an auto dolly and tow the car...This is the safest solution
GtSaucke
Reg. Apr 2007
Posted 2007-04-18 1:22 PM (#59548 - in reply to #59499)
Well Realizing that this would be that safest solution now comes the part about the cheapest. And i know you can't have it all these days, but the reason for buying a trailer and doing it that way is to keep cost down, because the trailer could be sold once the trip is over. I do appreciate that advice though, I'm just pretty sure thats out of my bothers budget.
Posted 2007-04-18 1:37 PM (#59550 - in reply to #59548)
Originally written by GtSaucke on 2007-04-18 2:22 PM
Well if he wrecks by hauling a trailer that is too heavy for his car...then he will get NOTHING...some of the hills in Idaho are not easy...
Travel costs are deductible on your income tax...
Depending on exactly how much weight his possessions come to, then he might want to buy a Wells Cargo utility trailer thru this outfit
http://www.maupintrailers.com/products.htm
and pick it up from the factory...cheapist prices I've seen...
Posted 2007-04-18 1:56 PM (#59551 - in reply to #59473)
Here is a followup piece of information to consider...
1995 Ford Taurus LX was equipped with the optional 3.8-liter V6. With the same horsepower as the 3.0-liter but more torque lower down (215 lb.-ft. at 2200 rpm rather than 165 lb.-ft. at 3250 rpm), the optional engine has much better acceleration.
If your brother has the 3 liter engine...he will RUIN his car towing almost any horse trailer across country...165 lb.-ft. at 3250 rpm at every start across the country will do serious damage to the drivetrain...
GtSaucke
Reg. Apr 2007
Posted 2007-04-18 2:20 PM (#59552 - in reply to #59473)
The reply with the link to the enclosed cargo/utility trailers is a bit more what i was looking for, i would never want to advise him to pull a horse trailer or any trailer for that matter that would pose a driving hazard or could cause damage to his car. He needs to make it here alive in one piece and with a working vehicle.
Terri
Posted 2007-04-18 2:43 PM (#59555 - in reply to #59552)
200050010010010025
You also need to consider depreciation on the new trailer.  You will not get what you paid for it when you sell.  It may be cheaper to get a rental trailer than to loose the money on a resale.
RoperChick
Reg. Dec 2005
Posted 2007-04-18 3:54 PM (#59560 - in reply to #59551)
Originally written by PaulChristenson on 2007-04-18 11:56 AM
I agree, just about any trailer that is big enough to haul even a small houshold is really going to stress the entire drivetrain especially the transmission.  In a vehicle that is 12 years old, unless the transmission is fairly new and has a cooler on it, my guess is the tranny wouldn't make the whole trip.
Reg
Posted 2007-04-19 6:32 PM (#59637 - in reply to #59473)
2000500100252525
It isn't going to be easy, but if you/he can figure out what sort of total weight he NEEDS to haul (not what he wants to take) he might be able to do it with a snowmobile trailer.
Some have hard covers (clamshell), they're relatively light and he might be able to stay under the 2,000 GVW.
At a guess 600~700 lbs for a 2 sled trailer capable of hauling a pair of 600~700 lb sleds might do it.
If he has to go cheaper than that, delete the clamshell top and use tarps with LOTS of bungie tie downs. Carry spare tarps too, the wind will rip them on a long journey if they're not tied down WELL !
