Removing carpet from dressing room, it's hard!!
Last activity 2007-03-21 5:50 PM
9 replies, 5634 views
labellemaldo
Reg. Mar 2007
Posted 2007-03-19 5:05 PM (#57335)
Subject: Removing carpet from dressing room, it's hard!!
I just bought a used featherlite and I'm trying to remove the carpet in the dressing room, it is n-a-s-t-y!! It is so so so hard to remove, I have half of it undone, but underneath, it has 3M adhesive spray and it is there to stay!  I am pooped and my poor hands can't take it anymore, any suggestions on what will loosen up that adhesive? By the way, I called the dealer and that's what they said they use to make the carpet stick. Seems to sticky to me but maybe over time, it gets really gooey. They had no suggestions other than to keep pulling!
greyhorse
Reg. Nov 2005
Posted 2007-03-19 9:14 PM (#57346 - in reply to #57335)
Subject: RE: Removing carpet from dressing room, it's hard!!
Are you using a scraper or just pulling it loose? A stiff putty knife can make a good scraper that will help you get it up as you pull it back, TSC carries a scraper for carpets but that's probably too big for your dressing room. Most hardware stores should have a floor scraper for around $10 though.
BTW, it isn't any easier when it's glued down in your house.... I got to remove old carpet in my house that was glued down with that stuff.5
labellemaldo
Reg. Mar 2007
Posted 2007-03-20 6:23 AM (#57359 - in reply to #57346)
Thanks for the suggestion on the scraper, I went last night and bought after another friend suggested I do so. I also thought about using a blow dryer to heat up the glue and then use the scraper to remove the carpet, hopefully, it should come up easier. I saw on another website that 3M makes adhesive remover to make it a little easier too.
terri s
Posted 2007-03-20 9:05 AM (#57364 - in reply to #57335)
500100100100
You might consider renting a steam machine of some sort to see if that would loosen the glue also. Works great on wallpaper, so maybe...
labellemaldo
Reg. Mar 2007
Posted 2007-03-20 10:57 AM (#57372 - in reply to #57364)
Thanks guys for the advice. I did manage to get it off this morning. I used a blow dryer and voila!
farmbabe
Posted 2007-03-20 1:32 PM (#57382 - in reply to #57335)
1000500100100
 I also had that Dr carpeting in the LQ and hated it. I couldn't find a good way to rip it up so i just ocvered it up with the peel and press floor tiles. Been that way for two years and its great.
labellemaldo
Reg. Mar 2007
Posted 2007-03-20 5:58 PM (#57398 - in reply to #57382)
Originally written by farmbabe on 2007-03-20 1:32 PM
I was going to do that too but whoever ever had it before me, spilled what I think is Kopertox in a large area and not only was it soaked underneath, but it stunk really bad!
farmbabe
Posted 2007-03-21 7:40 AM (#57439 - in reply to #57335)
1000500100100
yes, your carpeting had to go. Koppertox is bad.....I hate the smell
Chevy71
Posted 2007-03-21 3:45 PM (#57471 - in reply to #57335)
Can you just put the insulation over the carpeting or does it have to be ripped out?
maccwall
Reg. May 2004
Posted 2007-03-21 5:50 PM (#57475 - in reply to #57471)
500
I don't see why you couldn't put the insulation over the carpeting. It should work and add a bit of insulation R-factor as well. If have to pull the carpet up try WD-40. Works really well.
