Awning
Last activity 2007-02-25 6:51 PM
7 replies, 5455 views
Orion
Reg. Oct 2006
Posted 2007-02-24 4:36 PM (#56225)
Subject: Awning
I am wanting to put a roll out awning on my horse trailer. I have a quote on a A&E and Carefree. The Carefree is considerably less expensive. Does anyone have any suggestions on which is better or are they about the same in quality and function?
robdnorm
Posted 2007-02-24 9:47 PM (#56236 - in reply to #56225)
Subject: RE: Awning
500
I am pretty sure I have both.  One on our C&C horse trailer.  The other on our Jayco camper.  I will try to see which one is on what trailer.  I am pretty sure that the C&C trailer has the Carefree and I prefer it compared to the A&E.  The locking mechanism on the handles to raise and lower is more user friendly.  I will double check and post later.  The camper is away on some warranty issues.  If I am right, I am surprised the Carefree is cheaper.  It seems to be a much heavier made awning.
HWBar
Reg. Nov 2005
Posted 2007-02-25 6:23 AM (#56243 - in reply to #56225)
Subject: RE: Awning
1000100100252525
Check to see if both quotes include the arms, They should be priced within $10-$20 of each other. The Carefree is the better awning due to the locking Mech. I bet the arms are not in the quote you have. They are about $250.
robdnorm
Posted 2007-02-25 12:31 PM (#56263 - in reply to #56225)
Subject: RE: Awning
500
Finally had time to check them out.  I would go with the Carefree.  It is on our horse trailer and really is easier to operate.  I would pay the extra $$  to get one compared to the A&E.  I use both most weekends and there is no comparison.  We will have the horse trailer and camper parked together and you can tell the Carefree is a heavier made awning when they are both pulled out side by side.
Orion
Reg. Oct 2006
Posted 2007-02-25 12:54 PM (#56266 - in reply to #56263)
Subject: RE: Awning
Thank you
Is the Creefree easy for one person to drop down and work with?
bbsmfg3
Reg. Dec 2006
Posted 2007-02-25 12:54 PM (#56267 - in reply to #56225)
Subject: RE: Awning
I'd suggest you be sure your comparing Apples and Apples, not Apples and Oranges. Both companies make a variety of different styles and models, some heavier duty than others.
robdnorm
Posted 2007-02-25 1:59 PM (#56273 - in reply to #56225)
Subject: RE: Awning
500
Both can be operated by one person.  The handles on the Carefree are easier to operate.  I agree that there are different models and designs.  You need to make sure that you spec out each model.
kershawsowner
Posted 2007-02-25 6:51 PM (#56283 - in reply to #56225)
Subject: awning
hello i had the carefree on my last horse trailer and i just bought a new trailer a yr ago and it has a a&e. the carefree seemed to be a little heavier.. it would depend on the price as to which one i would go with if not much difference i would go with the carefree if is was over a hundred bucks i would go with the a&e because i have had not trouble with it either. as to comparing some of the awnings are a heavy vinyl type and some are material.. my old carefree was the vinyl and the new a&e is more of material i like both they both work fine... good luck
