Ford F250 Towing
Last activity 2007-02-15 7:50 AM
14 replies, 6677 views
horsemom3
Reg. Feb 2007
Posted 2007-02-10 10:09 PM (#55365)
Subject: Ford F250 Towing
Looking for a 7' LQ 3 horse all aluminum trailer. Should my 2006 Ford F250 have any trouble pulling it?
annemarea
Reg. Feb 2007
Posted 2007-02-10 10:19 PM (#55367 - in reply to #55365)
Subject: RE: Ford F250 Towing
I have no experience in this area, but I'm planning on pulling a 3H with 8ft LQ with my 3/4 ton Chevy.... I do have airbags on the rear end which should help with the weight.  I had a friend who bought a 4H with 11ft LQ and he said it was too much for his 3/4 ton to handle safely.  He felt my truck was sufficient for what I'm wanting to buy :)
Good Luck!!
horsemom3
Reg. Feb 2007
Posted 2007-02-10 10:30 PM (#55368 - in reply to #55365)
Oh no! Now I have been reading about hitch extenders!! My truck has a short bed. It does have the longer wheel base. Shoud I get a hitch extender? The trailer I am looking at has a tapered nose.
Mini Oaks
Reg. Nov 2005
Posted 2007-02-10 10:48 PM (#55369 - in reply to #55368)
I have a 2006 Ford F250 Diesel Crew Cab Short Bed that has no problems pulling an Exiss 3 horse with 8' living quarters, total length is 30'. The horse trailer has a tapered nose and there is plenty of room between the cab and trailer. Of course if you jack knife it over 90 degrees, then it will hit the cab, but that will happen with a long bed also. I have a standard B&W Turnover hitch without the extender.
horsemom3
Reg. Feb 2007
Posted 2007-02-11 8:09 AM (#55380 - in reply to #55365)
THANKS!!!! That makes me feel so much better. Once I start reading stuff online, I get so paranoid!
Cloud9
Posted 2007-02-11 8:43 AM (#55383 - in reply to #55365)
100100100
Horsemom - you should be fine towing with your F-250. Check with Ford or look at your owners manual and get the GCVWR for your truck. It'll guide you as to how much weight the truck will pull. My Dodge Ram 250 4X4 diesel is rated to pull 13,200 lbs. Most 3h LQ trailers are lighter than that.
If you are worried about the short bed, adding a hitch extender is no big deal. A strong man and a good wrench is all you need. They're not a lot of $$$ and not expensive to have installed by any competent mechanic.
foxpointfarm
Posted 2007-02-11 10:13 AM (#55387 - in reply to #55365)
I have a 2006 F250 Crew Cab Diesel with a short bed. We pull an extra wide warmblood gooseneck with a tapered nose. The body of the the trailer is 102"  a twide  - we have no problems making a 90 degree turn. If the body of the trailer you are looking at is the typical 6 -6.5 feet wide, you will have no problems at all. Any wider, make sure it has a  tapered nose. I would recommend getting airbags for the rear if you are pulling a living quarters.
robdnorm
Posted 2007-02-11 10:17 AM (#55388 - in reply to #55365)
500
I pull a 10' LQ C&C with my F-250 and with three large horses in it and it handles just fine.
horsemom3
Reg. Feb 2007
Posted 2007-02-11 10:33 AM (#55390 - in reply to #55365)
Great thanks for the info. I have considered getting air bags put on. How much will that cost?  Any suggestions?  Thanks!!!! :)
robdnorm
Posted 2007-02-11 11:07 AM (#55392 - in reply to #55365)
500
I doubt you need the air bags.  Granted, it does squat the truck some, but not enough to really make a difference.  If you search on past topics for air bags, you will find most all the information you need including prices.
Homer Bell
Posted 2007-02-12 9:00 PM (#55459 - in reply to #55365)
I pull a 3 horse 7' LQ Aluminum Exiss with my 2005 F-250 Diesel and I was wondering if anyone responding to horssemom has the integrated brake controller that comes with the tow package?
I've been having such a lunging or surging problem that it's a pain to drive.
Mini Oaks
Reg. Nov 2005
Posted 2007-02-12 9:48 PM (#55461 - in reply to #55459)
Yes I have the factory tow package with the intergrated brake controller on my 06 F250 pulling an Exiss 3 horse with 8' living quarters and have had no problems, probably towed approx 10,000+ miles with it so for. Brake Controller is set on 8.5.
robdnorm
Posted 2007-02-13 8:09 AM (#55476 - in reply to #55365)
500
I've got the integrated brake controller on mine as well.  I have to adjust it from 3.0 to 7.5 depending on the trailer I am pulling at the time.  I have not had any problems with it once I got it adjusted to the trailer.
Posted 2007-02-15 12:30 AM (#55584 - in reply to #55459)
The mechanical operation of electric brakes is fairly simple, if power is available to the magnets, and the magnets are functional. Therefore, we will assume that mechanical problems such as
  • brakes being out of adjustment
  • worn shoes
  • broken springs
  • worn hub drums, etc.
will be self evident and easily identified for correction.
The majority of problems that occur with electric brakes can be traced to an electrical system problem.
Is the problem in the trailer or tow vehicle electrical components?
Checking the trailer first... Unplug the trailer from the tow vehicle and use a 12 VDC battery with a fuse or circuit breaker, for short circuit protection, to apply full 12 VDC to the pins of the trailer connector connected to the wires going to the wheel magnets. As you connect the 12 VDC source, you should hear a notable click as the magnets are energized and pulled to the flat drum surface. Another method of testing brake magnet operation is to place a compass near the hubdrum.
 If, for example, you had brakes on both axles of a tandem trailer, you should go to each hub drum and assure that each brake cluster magnet is operating. If you could hear brake magnet activation on 1 axle and not the other, you may well have a bad wiring connection on the trailer wiring harness.
Conversely, you may hear 3 magnets click but not # 4. Closer inspection may indicate a bad magnet or a bad wire connection at that magnet.
 CAUTION: If a short circuit exists in the trailer electrical system, you could receive burns from melting electrical components if you do not use a fuse or circuit breaker for over current protection when connecting the test battery.
If all magnets click aggressively, the trailer electrical system should be in order, if the wire size is large enough to handle voltage drop. NOTE: Be sure that the brake magnet (-) negative wire is the same size as the positive (+) wire and be sure not to connect the negative (-) return wire to the brake backing plate or trailer frame.
 The negative must return thru the trailer plug and connect to the tow vehicle negative for optimum system performance. It is also essential that brakes be PARALLEL WIRED not series wired.
Posted 2007-02-15 7:50 AM (#55600 - in reply to #55476)
1000500100100100252525
I have the F-250 super duty crew cab gas with intergated brakes controller and have no problelm . I haul a eby stock combo with two draft horse and eveything was just  fine
