Trailer lights/wiring??
Last activity 2007-02-06 5:22 PM
7 replies, 4711 views
ksCowgirl78
Reg. Jun 2005
Posted 2007-02-06 2:45 PM (#55135)
Subject: Trailer lights/wiring??
My marker lights on my 98 S&H horse trailer are not working, but I have brake lights and turn signals. Would this be the wiring on the whole trailer or just the plug wiring? I have not inspected the wiring on the trailer yet, but the plug is kind of loose.
perfect11s
Posted 2007-02-06 3:12 PM (#55136 - in reply to #55135)
Subject: RE: Trailer lights/wiring??
 maybe worth checking inside the plug to see if a wire has been pulled out hope this helps hey dodge city sounds fantastic I have  a picture in my mind of  ,outlaws, shoot outs ,horses tied up outside the saloon
or maybe im just a stupid brit with a vivid amagination whos seen too many westerns
Edited by perfect11s 2007-02-06 3:14 PM
ksCowgirl78
Reg. Jun 2005
Posted 2007-02-06 3:19 PM (#55137 - in reply to #55136)
Originally written by perfect11s on 2007-02-06 3:12 PM
Well..... I think you may have seen too many westerns!!!! No horses to be found on the streets or a good saloon. Outlaws and shootouts, well, those may still be around!!
perfect11s
Posted 2007-02-06 3:45 PM (#55138 - in reply to #55135)
Great thank you , hope you  get your lights woking ok...I wish could come over and take care of it  for you  ..
maccwall
Reg. May 2004
Posted 2007-02-06 4:22 PM (#55140 - in reply to #55138)
500
I would use a test light and check each contact on both the connections. If your test light lights up them your connections are fine and it's in the wiring. Just would have to follow the wire and see if it has a short or is cut. Could be your lights too. I've had lights get wet inside and they are done after that. Gave me an excuse to replace them with LEDs.
perfect11, you just keep watching your westerns as I'm sure, thanks to the movies, some of us Yanks have a vision of what Cheshire England looks like (jousting and knights and such)
Edited by maccwall 2007-02-06 4:23 PM
ksCowgirl78
Reg. Jun 2005
Posted 2007-02-06 4:45 PM (#55141 - in reply to #55135)
I will do the testing on the lights, I'd forgotten we had a tester for that. About the LED lights, is that something I can put on a steel trailer myself, or do trailer people need to do it?
maccwall
Reg. May 2004
Posted 2007-02-06 5:08 PM (#55143 - in reply to #55141)
500
Shouldn't be too difficult. Depends on what type of lights that you have. Mine have the 2 little prongs on the bottom. They just pop out and you pop another in. Some I know you have to replace the base but for the most part it's 2 screws to take out, cut the 2 (or sometimes even 1) wire(s), put on 2 wire connectors to splice the wires back together on the new light and then screw the base back on. I have seen some that are riveted and that can be a pain. Good place to get them is here: http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=T...
They seem to have the best prices and carry many different kinds.
Hope this helps.
Posted 2007-02-06 5:22 PM (#55144 - in reply to #55135)
Look at the bottom of the Horse Trailer World home page. You will see the words "trailer tech", under that, click on  "trailer wiring". You will find it, some good info there.
