Question about Stripping LQ
Last activity 2007-02-03 11:30 AM
3 replies, 3394 views
Rose66
Reg. Dec 2006
Posted 2007-02-02 4:43 PM (#54934)
Subject: Question about Stripping LQ
Someone told me that I needed to put wood stripping in my LQ after I insulated it because if I attached my paneling directly to the metal braces of the trailer that condensation would warp my paneling, but what keeps the condensation from bucking the wood stripping?
soundhorse
Reg. Aug 2006
Posted 2007-02-02 5:32 PM (#54937 - in reply to #54934)
Subject: RE: Question about Stripping LQ
Most conversion companies strip the trailers first, then wire, plumb, then insulate.  Most use a batt insulation that has a R-8 value.  Most are using stripping from 3/4" to 1 1/4" thick.  If you insulate with the vapor barrier to the inside you will not have any issues with warping
acy
Reg. Oct 2006
Posted 2007-02-03 6:24 AM (#54966 - in reply to #54934)
my old trailer had 1/2 inch plywood paneling over the insulation and it never warped.
racesarabhorses
Reg. Oct 2005
Posted 2007-02-03 11:30 AM (#54984 - in reply to #54934)
Originally written by Rose66 on 2007-02-02 4:43 PM
This is a good question.  I want to know what LQ companies do.  Maccwall installed his LQ by framing after insulating, then putting his paneling up and building his cabinets in.  Sounds like a good idea to me, and is probably what I'll do.  It gives a chance to put another layer of insulation in and allows for wiring and plumbing to be run and completely hidden.  Would be nice to know what LQ companies do, though...
Mike
