towing mirrors
Last activity 2007-01-26 12:21 AM
12 replies, 4919 views
cttwdfm
Reg. Dec 2006
Posted 2007-01-23 9:22 AM (#54322)
Subject: towing mirrors
Anyone know what is the best tow mirrors for a 07 Dodge Ram?  The little mirrors they supply with the round sticker on the top don't work at all for a long trailer.
Spooler
Reg. Aug 2006
Posted 2007-01-23 10:24 AM (#54324 - in reply to #54322)
Subject: RE: towing mirrors
50025
Do you have the factory Tow Mirrors????  I have no issues with mine.  Takes some getting use to on setting the adjustment correctly.
cttwdfm
Reg. Dec 2006
Posted 2007-01-23 10:46 AM (#54325 - in reply to #54322)
I'm not sure if they are the factory tow mirrors.  It seems to me that they should be extended out further in order to see the trailer properly.  I'll ask the dealer.  The truck is the 07 TRX 3500 dodge 5.9 l. diesel.
hav2ride
Posted 2007-01-23 11:01 AM (#54327 - in reply to #54325)
1000500100100
Are you sure you have the mirrors adjusted correctly? Many people have them veiwing way too much of the tow vehicle, in other words, they are turned in toward the truck's sides too much.
cttwdfm
Reg. Dec 2006
Posted 2007-01-23 11:11 AM (#54328 - in reply to #54322)
Thanks, maybe that's the problem.  I just got a new trailer and it's quite different than my last one (3 H. gooseneck with lq as opposed to 2 H straight haul) so haven't got used to hauling it yet.  I'll check out the adjustment.
Spooler
Reg. Aug 2006
Posted 2007-01-23 11:18 AM (#54330 - in reply to #54325)
50025
Originally written by cttwdfm on 2007-01-23 2:46 PM
Here is how you can tell if they are.  The factory tow mirrors are more of a rectangle shape laying down.  Grab the mirror housing on the inside.  Try to lift up on it.  If you have factory tow mirrors they will pivot on the outside part of the mirror and you will have a rectangle standing up on end. Re-adjust the mirror.
Hope this helps.
hav2ride
Posted 2007-01-23 11:21 AM (#54332 - in reply to #54328)
1000500100100
I set my mirrors so that I can JUST see the rear fenders of the truck, no more. That's all you need to see. That way you should have the rear fenders of the trailer in view too. That's all you need to see of the trailer. You want to make sure that your mirrors show you what is in the lane next to you and where your rear wheels are (for curbs and lanes), not the where your truck doors are. :)
Spooler
Reg. Aug 2006
Posted 2007-01-23 1:17 PM (#54346 - in reply to #54322)
50025
With an 8 foot wide trailer it is even more of a pain.  I use the small mirror to see the truck fender and the regular I can't see the side of my truck.  Need that wide view for turns so you can see the curbing or end of the trailer in a turn. Takes some getting used to.
Reg
Posted 2007-01-23 3:28 PM (#54362 - in reply to #54322)
2000500100252525
I think you only need to see your trailer wheels once in a very long while.
You should KNOW that you ARE in your lane. After a small amount of practice you should also know that your trailer is clearing everything on turns.
When backing around a curve the trailer wheels on the inside of the curve are the ones you need to pay attention to, mirror span is not an issue here, you lose sight of the other trailer wheels anyway.
BTW, most "8ft" trailers are in fact 8ft 6in at the outside of the tires, same axles.
cttwdfm
Reg. Dec 2006
Posted 2007-01-25 4:41 PM (#54500 - in reply to #54362)
Thanks to Spooler...duh, yes they are factory mirrors...I checked and lo and behold they turn around just like you say.  Geez, it would help if I read the owners manual but this is my third Dodge and I hadn't realized they'd changed them.  Thanks for your help!!!
Spooler
Reg. Aug 2006
Posted 2007-01-25 6:38 PM (#54507 - in reply to #54322)
50025
Your welcome, but not all of the Dodge trucks have factory tow mirrors.  It is an option.  In my local area the dealers always order the trucks with the Tow package and Tow mirrorsn because of the farmers and horsey people.
hav2ride
Posted 2007-01-25 6:47 PM (#54508 - in reply to #54362)
1000500100100
Yep, you should know where the trailer wheels are, but I like to make sure I am keeping the long rig between the lines (or off the barriers, as the case may be) when going thru narrow cattle shoots on a curve. I also will check back there once in a while to make sure there's no smoke coming off the wheels. I had a friend go down the road with her wheel on fire and didn't know it because you can't see any part of her rear wheels in her mirrors. I also glance in my mirrors for tight turns so I never run over curbs. Have the mirros adjusted right and you don't have a blind spot either (unless there are 3 lanes or more).
Edited by hav2ride 2007-01-25 6:48 PM
kershawsowner
Posted 2007-01-26 12:21 AM (#54519 - in reply to #54322)
i have a 05 3500 dodge the only problem with the mirrors is having to readjust them all the time from in to out position...they need to come up with a auto adjustment when you pull the mirrors back in... good luck on pulling your new trailer..
