06 dodge 3500 mega cab
Last activity 2006-12-08 6:30 PM
7 replies, 4720 views
BDANIELS5467
Reg. Nov 2006
Posted 2006-11-28 2:03 PM (#52007)
Subject: 06 dodge 3500 mega cab
i was if anyone with 06 dodge mega cab with 6 speed manual has any problem backing gooseneck trailer. my truck seems to jump up and down real bad in the rear end. it does not do it with a bumper pull trailer only with gooseneck. i was wondering if i put a hitch extenter on the trailer that this would help . if someone could help that would be great .
Reg
Posted 2006-11-28 5:55 PM (#52013 - in reply to #52007)
Subject: RE: 06 dodge 3500 mega cab
2000500100252525
Originally written by BDANIELS5467 on 2006-11-28 2:03 PM
Hi and Welcome to the Forum.
I don't have that truck, but the symptom could be independant of the truck make/model/year.
Are you using any brakes at the time it does this ?
Are you still letting the clutch in ?
RoperChick
Reg. Dec 2005
Posted 2006-11-28 6:03 PM (#52015 - in reply to #52007)
Here's a link to a Dodge truck forum, maybe someone there has experienced the same thing and can help you.
http://www.dieseltruckresource.com/dev/index.php
Spooler
Reg. Aug 2006
Posted 2006-11-28 7:57 PM (#52019 - in reply to #52007)
50025
Is your truck a 4wd or 2wd.  If it is a 4wd then put it in Low range when backing and it will help.
Edited by Spooler 2006-11-28 7:59 PM
mingiz
Reg. Jul 2004
Posted 2006-11-29 5:06 AM (#52025 - in reply to #52007)
 I have a SB in my F250 ext cab. I towed my 24ft 5th wheel but felt uncomfortable when turning.Always looking over my shoulder to see were the trailer was when turning... So before I hooked up my GN I installed an extender hitch. Have no problems now can turn as tight as I need to. I would suggest getting one. Cheaper than a body / glass shop.
ND COWBOY
Posted 2006-11-29 4:02 PM (#52036 - in reply to #52007)
I have the same problem with my '06 3500. I put the 4wd into low and don't have any trouble. It seems to back too fast in 2wd.
hounddog
Reg. Dec 2005
Posted 2006-12-02 5:52 PM (#52126 - in reply to #52007)
1000100100
They have wheel hop or another term is axel wrap.The 06 6 speed had got a lower reverse and 1st gear compared to my 03 but the issue is still with them.My 03 does it also.A extender on the hitch will NOT help this issue.
racesarabhorses
Reg. Oct 2005
Posted 2006-12-08 6:30 PM (#52341 - in reply to #52007)
I had the same problem with my '06 Ram 3500/extended cab/manual transmission.
Turned out, the brake on the trailer was stuck on.  The truck idled it forward in 2nd gear, smooth as silk.  Left 5" ruts in my lot to prove it.  When I backed the trailer, I realized the brakes were stuck because it hopped as you've described.  Check your pins on your electric hookup.  Sounds like your brake and constant hot wires are crossed.  Easy to fix.
My truck is 2 wheel drive.  4x4 put the bed rails of the truck too close to the trailer for the uneven terrain on the farm.
Mike
Edited by racesarabhorses 2006-12-08 6:32 PM
