Choice of saddle blanket
Last activity 2006-09-29 9:03 AM
16 replies, 6589 views
cowgirl98034
Reg. Apr 2004
Posted 2006-09-13 12:21 AM (#48427)
Subject: Choice of saddle blanket
What kind of saddle blanket do you all use for long distance rides?  I have had people recommend wool, neoprene, synthetic...  I am looking for something that keeps him comfortable and provides protection for his back.  He's an Arab with the typical shorter back.  I borrowed a thick coolback blanket the other day for a really long ride and he was so sore.  It may have been the length and difficulty of the ride, but I am going to buy a new saddle blanket and wanted a few opinions before making the purchase.  Thanks!
deranger
Posted 2006-09-13 6:23 AM (#48433 - in reply to #48427)
Subject: RE: Choice of saddle blanket
5001001001001002525
I really like dixie midnight blankets. There was a thread on this forum about a year ago about saddle blankets and someone suggested them. It's a great blanket, a little pricey, but worth the money. We have a little arab gelding and he's prone to being a little sweaty when ridden. All of our horses are arab, or arab mix except for one and he's part draft. The dixie midnight pads work well for all of them and it keeps our little gelding a lot cooler than any combination of pads I've tried on him in the past. They have a website, just punch in dixiemidnight.com and you'll go right to their website. I think they are located in Florida if I remember correctly. They ship quickly and have a pretty good selection of different size pads. Happy trails.
gemm
Reg. Feb 2005
Posted 2006-09-13 11:33 AM (#48453 - in reply to #48427)
100100100100252525
I use a Supracor on my 1/2 Arab. They're pricey, but IMO worth the money. However, before you go spending a bunch on a new pad, does your saddle fit well? I think there are many good pads out there that will work with a well-fitting saddle, and none of them are to blame if the saddle is a poor fit. It's worth checking. Maybe your current pad is OK after all.
mox
Reg. Aug 2006
Posted 2006-09-13 11:57 AM (#48455 - in reply to #48427)
I've got a Supracor oversized pad that works GREAT!   It's for my reining saddle (dale martin custom) which is too nice for trail rides (I'm broke and poor but my horses live very, very comfortably).
I use a wool navajo under the Supracor so it will last longer.  With my reining saddle on top of the supercore, I can get my hand under the saddle & pad effortlessly even around the withers.  My horse sweats evenly and it's super comfy.   NO pinch points, even with other saddles.
I'll get another one for my barrel saddle (also my 'trail' saddle) some day.
I swear by Supracor
Edited by mox 2006-09-13 11:59 AM
Longrider
Reg. Oct 2004
Posted 2006-09-13 8:12 PM (#48490 - in reply to #48427)
10010010025
I'll bet it's more of an ill-fitting saddle problem than a blanket. The saddle is pinching or has pressure points causing the soring. Or, it could also be the rider's weight distribution in the saddle. I've learned to make sure that the saddle fits first. Also, on long rides make sure you watch how you sit in the saddle. At a trot I ALWAYS post in the saddle. I also make sure that at a walk I am not just constantly letting my butt put all the weight on my horse's back. I prefer the Toklat cool back pads WITH a correct fitting saddle.
Posted 2006-09-13 11:47 PM (#48507 - in reply to #48427)
I also like the dixie midnight.  I lay a Woolor Acrylic Navajo blanket over it.
They allow the sweat to run down the side of the horse and not into the blankets.
I don't need to wash my other blankets very often.
The horses back stays cooler.  Now if I could just find them in colors other than Midnight blue.
cowgirl98034
Reg. Apr 2004
Posted 2006-09-13 11:53 PM (#48508 - in reply to #48427)
Thanks for the pointers... I had experienced help in picking and fitting a saddle, so I sure hope that saddle fits well.  It is a few inches longer than my other saddle (a very small barrel saddle) so I imagine I am sitting in a slightly different place on his back. The blanket I borrowed was thick, but squashed down in some spots and too long for him.  I brushed it up a lot before using it, but obviously it wasn't enough.  It was a 32" and the back of the blanket hit him right where his hip rises up. That was a sore spot for him. Another factor was that he hasn't been on an 8 hour ride until Sunday, and we did some serious climbing (3500' elevation gain) and then had to come back down.  There were numerous leaps up and down, about 2' high, of rock ledges, roots, etc and that caused him to use every muscle he had available.  He wouldn't drink from the streams which couldn't have helped his muscle soreness.  I rested him every so often, let him graze a while and we even led them down for about 1/2 hour a couple different times, to give them a break.  We had to keep moving so we got down off the mountain before dark.  I posted pics on the camp and trail thread if you care to see where we went.  I will look into the 2 brands of blankets mentioned and see which one I like.  He is fine today, no soreness at all which is a relief.  He is a very very sensitive horse, and sometimes it's hard to tell if he's really hurt or over-reacting.  When he gets his shots, you can't touch him for a few days, especially on his neck.  He gets so grumpy!  You can't use a medium or stiff brush on him either.
gemm
Reg. Feb 2005
Posted 2006-09-14 12:31 AM (#48510 - in reply to #48427)
100100100100252525
You're right. He might just be sore from an extra long ride. You could try him again with the same saddle/pad set up, but with a shorter ride, and see if he is less sore. That sure would save money you could spend elsewhere!....And I know all us horse owners have LOTS of places we can spend more money! Also, you can check out the AERC (endurance) forum for pointers on saddles and pads. So many of the endurance riders have Arabs(short backs), put in long, hard hours and are more than happy to share their experiences. A very nice group from my personal experiences. Good luck!
cowgirl98034
Reg. Apr 2004
Posted 2006-09-14 11:00 PM (#48570 - in reply to #48510)
Thanks for the advice. I am hooking up with a local gal who endurance rides and needs a training partner. We will try a 20 mile ride in the area, but not mountainous, so my horse should be fine with that. Also won't take 8 hours like the 17 mile mountain ride. I'll try him with a good wool blanket, not too bulky, and see how he does. I'd love to get in to endurance riding, but it seems to require more time to train (horse and rider) and compete than I have at this point in my life.
AbbyB
Posted 2006-09-17 9:58 PM (#48685 - in reply to #48427)
I feel you can't do any better than wool - & in my opinion, the 5 Star ( http://www.5starequineproducts.com/5StarWoolPads.html ) is the best one out there.  It is the only 100% all wool pad (alot of others say they are, but when you ck the "ingredients", you see other "stuff" in them.)  They do not compress like other pads, last forever, clean up nicely & most of all, they BREATHE & do not create heat on a horses' back.
Wildcat Custom
Reg. Sep 2006
Posted 2006-09-19 6:06 PM (#48807 - in reply to #48455)
I ask the same thing ask mox when I read your question.  I would start with being sure you have a well fit saddle with the correct bars for your horse then go with a reputable pad.
Posted 2006-09-20 12:09 AM (#48818 - in reply to #48570)
A lot of sore backs are not from bad pads.
Some horses get excited. They get their head up and hollow out their back. This causes even a good fitting saddle to bridge across the back. Causing sore loin muscles.
Watch your horse during the ride. see if he is relaxed and staying collected.
My grey gelding is joy to ride alone or with my daughters on his herd mates. But take him to a CTR where there are 50 other horses and he gets all wound up.  Head held high, back hollow and I guarantee he will be sore after the ride.
cowgirl98034
Reg. Apr 2004
Posted 2006-09-20 9:12 PM (#48858 - in reply to #48818)
Wow - that is something I never thought of before. He did get wound up, initially from the trailer ride up there... it was a little longer than he's used to, plus he was alone in the trailer. He seemed fine on the ride though, never one hint of a sore back. I wouldn't have even known if I hadn't poured some water on his back to wash off the dried sweat. He got tense during the ride a few times, because we crossed a few bigger streams, had to cross some tricky puncheon bridges, and he was very worried about being tied in the trees while we hiked up to the ridge (about 100 yards away). The other horses were standing so calm, resting, and he was trembling and called to me when he saw me coming back. "where did you go? don't you know there are bears out here"? was what he seemed to be saying - he was fine every time I got off then and on, and I truly never noticed once that his back was sore, until he was unsaddled. I felt really bad about that. I have since taken him on a 1 hour ride and no problem at all - I used a 100% wool blanket and a think wool felt pad on top of that and he was fine. I'll work up to longer rides and keep checking his back, just to be sure.
Posted 2006-09-22 11:40 AM (#48953 - in reply to #48685)
1000500100100100252525
I think painted horse is on to something. I use wool western pad i think they work the best( wool or cotton ) every thing takes time but it is worth it at the end.
horse nugget
Reg. Sep 2006
Posted 2006-09-25 12:15 PM (#49090 - in reply to #48427)
I had a simaliar problem way back when. I bought a Corrector pad from Len Brown. It works great and is used on more than one horse. the web page is www.correctorpad.com
bjhouten
Posted 2006-09-25 4:45 PM (#49108 - in reply to #49090)
5002525
I have one of these, lightly used, I'd sell for real cheap. email me if interested. It the westren style.
-Betty
Edited by bjhouten 2006-09-25 4:47 PM
chevalnoir
Reg. Jun 2006
Posted 2006-09-29 9:03 AM (#49345 - in reply to #48427)
I would really investigate saddle fit more.  So much back pain is caused from a poor fitting saddle.
Unfortunately, there are MANY saddle fitting "experts" who really don't have a clue.  Another factor to consider is that just because a saddle "fits" doesn't mean it "SUITS" the horse.
No saddle pad or blanket in the world will fix an ill fitting saddle.  Often, they make them worse.
