Miley 3H BP
Last activity 2007-02-27 5:45 PM
14 replies, 7716 views
Roy23
Reg. Aug 2005
Posted 2006-09-05 7:06 AM (#47865)
Subject: Miley 3H BP
I know that every person has a favorite brand, what opinions are out there about Miley Trailers? The 3 horse bumper pull more specifically. I am looking to buy relatively new 2005-2007. I have not physically seen a Miley near me but understand they are pretty popular in other areas of the country.  Is there a reason why they are so affordable? Any insight anyone has is greatly appreciated.
statzk
Reg. May 2006
Posted 2006-09-06 9:37 AM (#47944 - in reply to #47865)
Subject: RE: Miley 3H BP
My wife and I recently purchased our first new trailer.
While looking for a budget trailer (our budget was $7000 for a 3H BP) we found 3 that were galvaneal and a bunch of steel trailers.  Only a few brands were available locally so we checked them all out.
First the galvaneal:
Morgan Built (not Miley as I previously thought)- most expensive of the galvaneal, but still a good price.  Had the nicest fit and finish of all the galvaneal trailers, but lacked drop down windows and some other things.  Had a low weight and heavy duty axles (5200lb IIRC) but they may have been an added option.  Latches and other things caused a lot of paint chipping and thus rust.  More rust than I would have liked to see on an '06 trailer, but not as bad as the Titan.
Titan- cheapest of the galvaneal, great price.  Fit and finish was marginal, and the drop down feed windows were somewhat of a joke- up way too high to be usable, and no running boards to help.  I am 6'3" and I could hardly reach to open them, much less actually feed or water.  No way my wife could have done anything with them.  Lots and lots of rust for a trailer that was manufactured only a few months previous.  Latches and other things felt cheap, and they had no rubber pads or anything to keep them from banging into the paint.  Hinges and other places had lots of rust, whole rubber mat had a nice orange coating to it.  Trailer weight empty was 4400 lbs, and the trailer only has 3500lb axles.  That leaves 3100 lbs total for 3 horses and tack.  YIKES!  Yet with all this weight, the trailer walls felt very very flimsy and thin.  Not a bad trailer if you added running boards and heavy duty axles.  However we wanted a trailer we wouldnt have to do anything to, after all we were purchasing a BRAND NEW trailer.
S&H- Only got to look at a 2H BP, but seriously considered ordering a custom built one.  More like the Miley than the Titan, not as much rust but still some (considering the claims of galvaneal, yet none of the steel trailers we looked at had as much rust as any of the galvaneal!).  Fit and finish wasn't that great, welds were fine but a bit sloppy (I am picky, having been a welder).  A fine trailer, and for the price I would choose the S&H over the Miley, but in other parts of the country I have seen the Miley cheaper- either one would be fine.  Miley also only comes stock with the 3500 lb axles and 6'6" height.  Did not get to see a 3H and verify the weight but was told by a sales person the weight of the 3H BP is 3600lbs.  Now 7' will ad a bit of weight, but still OK.  Would need to get heavy duty axles...
Corn Pro- very inexpensive, more than a thousand dollars cheaper than any others (close to $2K).  However it lacked any bit of style.  I already had an ugly stock trailer, so Corn Pro was not really an option for very long.  ;-)  Fit and finish were pretty solid though, trailer felt like it was built like a tank.  Too bad it looked like a tank too.  Didn't even look at trailer weights or axles on this one, as it fell out of the running right away.
Moritz- very nice stock combo 3H BP trailer.  However the price was just as high as the Titan and S&H with drop down windows.  Fit and finish were nice, no rust other than on the latches a little bit.  Granted the trailers they had in stock were built the same month we were looking at them!  Style and functionality seemed fine, weight was pretty low, came std. with 3500 lb axles, but weight was around 3300 I believe.  Not bad, would have been happy with it as it seemed very solid and strong.
Featherlite- well this is the one we bought, so that should tell you something right there!  Style was first class, was very very solid build.  Corrugated steel sides really felt beefy, yet empty weight was one of the lowest.  The price on the STL trailers was pretty high (almostas much as the Miley) yet we found an '05 on the lot that was still new.  Even a year old sitting on the lot it had less rust than any of the galvaneal except maybe the Miley- the Titan was parked right next to it and was a year newer.  The difference in the amount of rust made us rule out the Titan (then the weight issue came up).  The price on the '05 was lower than any of the '06 models except the Corn Pro.  Even at the list price it would have been a close contest...  With the low price of the '05 it was a no brainer.  My big old draft horse will even fit in the last stall.  Not sure I'm comfortable with 1800lbs out back that far so she will be getting the middle and no horse in back.
Hope this helps.  Figured I would share my thoughts on the trailers I looked at.  We also looked at some used Sundowner and Hawk trailers, but didn't really want a used trailer (and in our price range they were all 5+ years old).  Please also take into account my thoughts on trailers are biased by the fact that I need to trailer an 1800lb draft horse who leans very hard into things.  She moved a pole barn wall out 8" just getting at an itch...  My comment on the Titan and others about thin walls are not to say they are not safe.  Just not safe for my horse!
Cheers!
~Kevin
Edited by statzk 2006-09-06 8:45 PM
kcnyellow
Reg. Aug 2006
Posted 2006-09-06 7:13 PM (#48005 - in reply to #47865)
I was looking at the Mileys and I thought they were aluminum skin over steel frame and not galvaneal.  Did I miss something?  I think for someone who needs an affordable trailer and can't quite step up to the all aluminums, the Miley looks pretty nice.  I just wish someone who purchased one would weigh in with a response.  That would really be helpful.
statzk
Reg. May 2006
Posted 2006-09-06 8:44 PM (#48009 - in reply to #47865)
Whoops, my wife has corrected me- I thought we looked at a Miley (it was one of many trailers saved to my list) but we looked at a Morgan Built. I guess we never made it to a Miley dealership. Hey it WAS like 3 weeks or so ago... memory isn't what it used to be. I will edit my post to say MB not Miley. And I thought I had something to contribute to this thread. LOL! ;-)
~Kevin
Roy23
Reg. Aug 2005
Posted 2006-09-07 10:50 AM (#48048 - in reply to #47944)
Thanks for your response. Your information was very helpful despite the mistake, no sweat. There is so much to compare! I really like the looks of the Miley and check anxiously everyday on her for a response that will aid as a push to just buy it...
I have another question- I see you are from the middle part of the country. I priced out a corn pro 2007 from a local dealer(upstate NY) and the estimate was about 7800. I found a 2006 corn pro for sale by an individual in the midwest for 4800. Does $3000 seem like a big difference to you? I was wondering what the corn pro 2007 would go for in that region or if it is the same?
Man, there is a big gap between 2 and 3 horse trailers...ahh life's dilemas...
statzk
Reg. May 2006
Posted 2006-09-07 12:08 PM (#48052 - in reply to #47865)
Roy23-
Corn Pro's here in the midwest are cheap.  I have seen used 3H slants go for $3500 (for a couple year old used one, not a clunker from a past decade!) and the new ones are around $5K+ depending on options after you account for shipping charges.  Still not too bad, not anywhere near the $7K you quoted.  ALL of the trailers I mentioned were under $7500 asking price.  I believe even the Miley was near this price, and it does look like a sharp trailer from the pics.
If you are interested in Corn Pro check out AlbertReardon here on the trailers for sale listings.  Shipping to your part of the country is probably expensive as most of the trailers are made either in the midwest or down south...
They should be able to get a trailer delivered to you for $4-5 hundred give or take- still a lot cheaper than $7K!
Cheers!
~Kevin
Roy23
Reg. Aug 2005
Posted 2006-09-07 2:14 PM (#48060 - in reply to #48052)
Good to know, good to know... I have always wanted to take a trip out west- this sounds like a good reason to me.
I am new, very new to this site. I didn't catch what you were trying to explain?
thanks
nina
statzk
Reg. May 2006
Posted 2006-09-07 11:20 PM (#48096 - in reply to #47865)
Roy23-
Check out this seller: http://www.horsetrailerworld.com/home/searchtrailers.asp?DC=1rtrsal... that is what I was trying to explain to you. The company name is Albert Reardon trailer sales. I didn't purchase from them but that is the dealer I checked out the CP trailer at. Very good prices and they do high volume of Corn Pro trailers, as well as very friendly.
Cheers! Glad to be of any help at all, I'm fairly new to the trailering scene, however ridden shotgun on many X-country horse hauls.
kcnyellow
Reg. Aug 2006
Posted 2006-09-09 8:45 AM (#48175 - in reply to #47865)
I just had an opportunity to get a good look underneath the Miley's.  Someone was driving through Amarillo with a trailer load of them, so I got to look at the undercarriage.  They appear to have a substantial aluminum floor, cross beams support at what appeared to be about every 10". Also, noted on the rear gate that there are four hinges holding it.  It has just made me want to find a dealer and go look at the rest of the trailer.  I have been shopping for a trailer and I've looked at a whole lot of them, but truly, my needs are fairly limited; haul to the vet or haul to an occasional lesson.  I mean, I'd love to have a 4-Star or Hawk, but I can't justify that price for my needs.  If I can ever get to see the inside of the Miley, I know that would help me make up my mind, but it is triple wall construction with an aluminum floor and aluminum roof (better than fiberglass in TX with our hail).  My closest dealer is in Albq or OK City, so it will be a while before I can get over to see one.  I will write in when I finally do.....
missalli
Reg. Sep 2006
Posted 2006-09-10 9:30 AM (#48226 - in reply to #47865)
Miley was top of the line in the 80's, but disappeared in the market as the new aluminum manufacturer's appeared.  Universal now owns them, and re-introducing them with the Miley name is better marketing.  I have owned and sold several trailers and it is better to get a quality well made trailer because they sell faster and for more money.  Universal trailers makes it so easy to buy new that there is no market for their used product.  I like Elite, 4-Star, Platinum, C&C.  These brands don't depreciate as quickly.
Longrider
Reg. Oct 2004
Posted 2006-09-10 7:46 PM (#48250 - in reply to #48226)
10010010025
I've stated here before why Miley went out of business in the 80's. It wasn't because of the aluminum trailers popping up. The Drug Enforcement Agency seized all of Rex Cauble's assets for doing drug trade. And he got to go to the country club prison in Big Spring, TX to do "hard" time. He was using his trailer delivery network to also deliver drugs to different parts of the country. He also lost his ranch, Cutter Bill western wear stores, as well as his Miley Mfg. All because of GREED!!  I'm sure that the name copyright had expired and was picked up by UT since it was a good trailer and had name recognition.  Google Rex Cauble for more info.
trailer/truck newbie
Reg. Feb 2007
Posted 2007-02-27 4:36 AM (#56361 - in reply to #47865)
Hi There,
As you can tell by my username I am new to owning a truck and trailer. Two weeks ago I (very impulsively and with no research whatsoever) drove to a Ford truck/trailer dealership and decided to take the plunge. I bought a 2007 Miley 3 horse slant load bumper pull trailer and a Ford 150 V8 4.6 supercrew (interestingly, no trailer package was included, the dealership just added the hitch on once they realized that they had almost sold me a truck that had no hitch!). Hindsight is indeed 20/20. Considering the utter stupidity of purchasing those large ticket items with no research and not taking anyone along who actually knew about trucks and trailers ( I am involved in 4h so I had plenty of people to ask) I think I made out okay. After posting a query on this website I feel confident that I can pull my two horses (quarter horse and arab) the six or seven miles down straight roads to our 4h meetings in my new miley. However, in a few years I will definitely upgrade to a larger truck. It's hard when you are buying everything at once as there are budgets to consider.
Sorry, I am digressing. Back to my opinion of the miley. It was $12,000 canadian with the comfort package (rubber walls, matts and spare tire). THere is a dressing room/tack room at the front of the trailer. I did have to have the dealer send a repair tech out to install interior ties as there were none. At first they tried to tell me that these were "optional", however, after looking at the miley website product monograph the ties were clearly stated as standard features. THe tech came out and installed them. My tack room keys didn't fit the door so the dealer first said they would send new ones. Then they said that the doors are notorious for being sticky so they are sending me the same keys back to re-try. If they still don't work they will replace the door on the tack room. I still have yet to use the trailer once as I wanted to ensure that I could actually tie the horses in and that the tack room door wouldn't spontaneously fall open while I was driving. I am also having an equalizer hitch installed this week.
All I can say so far is that the dealership has been decent in fixing these problems but I can't help but wonder if there are are some quality issues if little things like this are popping up already before I have even used this brand new trailer.
Of course, I plan to practise pulling this trailer empty a few times to get comfortable with it before I put my horses in it. I am a little intimidated by all the negative comments I have read about the difficulty of bumper pulls however, I also think that this will only be problematic if I don't practise enough and have the patience to learn. I have several seasoned horse trailer drivers who have offered to come out with me and I am sure that they will also be in a better position than I am to offer constructive comments on the quality of the miley trailer. I will let you know what these thoughts are once I get out there and start using it (which will be later this week).
I'll keep you posted.
J
ponytammy
Posted 2007-02-27 9:55 AM (#56376 - in reply to #47865)
500100100252525
There is a Miley dealership close to where I live. I looked at these trailers last spring and was not impressed with the quality for the price. The stall dividers had metal sheets rivited onto thin tubular bars. The corners of the sheet metal had sharp edges where a shoulder or hip could scrape and cut the flesh. The trailer camper door was very flimsy and the drop down window hinges were very poorly constructed. Last I checked Mileys (Universal Trailer Corp) had merged with Featherlite so maybe the manufacturing will get a little better.
horsey1
Reg. Dec 2004
Posted 2007-02-27 11:12 AM (#56380 - in reply to #47865)
Tammy, Early Mileys had dividers like that, but not for long. Now the divider is an all-aluminum one similar to the Exiss model. Very nice. Another thing to remember is that the Mileys have been a "work in process". So each one gets a little better in quality, fit, finish, etc. So if you didn't like the last one, the next one will probably be better!
Reg. Feb 2007
Posted 2007-02-27 5:45 PM (#56426 - in reply to #47865)
Hi Tammy,
I went out and looked at the dividers in my miley trailer and as the last person who posted indicated the dividers are indeed aluminum and there are no sharp edges anywhere to be found. The drop down windows work fine and there are bars on them also. I like that feature better than the circle j trailer that a friend of mine has which has no bars. The horses stick there heads out as soon as they are loaded in and I can't help but wonder if that is dangerous. If they spook and try to rear they could do some serious head/neck damage. Anyways, that is my two cents.
Jo
newbie truck/trailer owner
