steel trailer with rumber floor?
Last activity 2006-07-28 1:34 PM
9 replies, 4903 views
shorthorse
Posted 2006-07-22 8:48 PM (#45253)
Subject: steel trailer with rumber floor?
     Is there any such animal?
               Thanks in advance...
                              Lisa
Dunoir
Posted 2006-07-24 7:02 AM (#45300 - in reply to #45253)
Subject: RE: steel trailer with rumber floor?
50010025
Probably not from the factory, but you can get one installed.
SLICKRNSNOT
Reg. May 2006
Posted 2006-07-24 8:40 AM (#45309 - in reply to #45253)
What the hell is a rumber floor ???
dylan1
Reg. Jul 2005
Posted 2006-07-24 10:27 AM (#45312 - in reply to #45253)
Titan makes steel trailers with the rumber floor, my trailer before the one I have now was set up that way, I thought the rumber was kind of slick, so we put rubber mats in. They say the rumber will never rot since it is made of recycled tires.
Dunoir
Posted 2006-07-24 11:24 AM (#45316 - in reply to #45253)
50010025
I have a '97 2H with the rumber floor and it's a great floor. No issues whatsoever.  I do have an aluminum frame and get that checked periodically.  I don't use mats with it as it provides cushioning for them and then I don't have those heavy mats to haul out to clean the floor.  I've never experienced any slippage with the floor in almost 10 years of regular use. (trailer 2-5 times a month year round)
Rumber is as the previous poster said, recycled rubber in sheets that is used instead of wood or aluminum.  Far superior in durability, but it does cost more.
Posted 2006-07-24 2:12 PM (#45322 - in reply to #45253)
I've had rumber in the last two trailers I've owned and it is great.
I have the tongue and groove planks on the floor and the 3/8" sheets on the walls.
More info at  http://www.rumber.com/
I've seen it in both Steel and Aluminum trailers. Usually as an add-on option.  Ask your trailer maker if he offers it.  If you are buying a used trailer,  you can install in any trailer just like 2x6 planks of wood.  Check the support website for support size and spacing.
SLICKRNSNOT
Reg. May 2006
Posted 2006-07-24 4:08 PM (#45328 - in reply to #45253)
HMMMMM learn sumten new every day,I thought it was just misspelled or I was readin it with a hangover.
Thanks for the info
jackbrat
Posted 2006-07-25 5:12 PM (#45395 - in reply to #45322)
500100
I bought a "Monarch" by Classic. They have rumber floors in their trailers, even the less expensive one, the "Cavalier". This is a STANDARD option on their trailers!
Love my new trailer! This trailer came standard with so many things! Just look and you will find some great deals!The Horse-Expo (an annual event)is a great place to buy a new trailer.
siseley
Reg. Jul 2006
Posted 2006-07-27 6:41 PM (#45537 - in reply to #45395)
 I bought a Classic Westerner 3 horse slant load bumper pull... Love that trailer. And as the other poster said, these trailers all come with the rumbar flooring. My arab, and my Quarter horse stand well and don't slip even when we go to the foothills for rides. REALLY easy to clean out too. Just pressure hose out and let dry. No corrosion problems or dry rot/ wet rot. The walls just shrug off the bumps from other folks horses too.
RTSmith
Posted 2006-07-28 1:34 PM (#45582 - in reply to #45253)
On the post of replacing 2x6 boards, be careful. Rumber's installation procedures call for cross-member spacing that is closer together that a wood floor generally has. Hence, one of the reasons it is an extra cost option is they have to build more frame from the trailer factory. Wouldn't want to see a direct changout & then an accident from sagging Rumber floorboards.
RTSmith
