Headlight Adjustment
Last activity 2006-07-04 6:07 AM
2 replies, 3072 views
texasjewel
Reg. Aug 2005
Posted 2006-07-03 5:36 PM (#43946)
Subject: Headlight Adjustment
I have a 2004 Chevy 3/4T Duramax that pulls my Merhow 3-horse LQ without any problems whatsoever, except the weight on the rear causes my headlights to blind oncoming drivers.  Would air bags eliminate this problem or is there a self adjusting gadget for headlights?  It would be a pain to realign the headlights each time I towed.  Thanks for any advice.
huntinfool
Reg. Jul 2005
Posted 2006-07-03 6:08 PM (#43949 - in reply to #43946)
Subject: RE: Headlight Adjustment
  The air bags would probably help , and I think you would really like the air bags for towing . I was having the head light problem you are describing with my Ford and slightly larger tires . The head lights didn't seem to bother any body until I was towing my goose neck trailer . I ended up having the lights adjusted . It could be just me , but now that they are adjusted it doesn't seem like my lights are shining as far forward when I am not hauling a trailer .
Reg
Posted 2006-07-04 6:07 AM (#43984 - in reply to #43946)
2000500100252525
Originally written by texasjewel on 2006-07-03 5:36 PM
My '03 1 ton came as a chassis/cab, but even before the flat bed was added the lights were high, straight from the factory they were just aimed HIGH.
Once adjusted I had no problems with oncoming drivers - correction, they no longer had problems with me.
Since putting the air bags on my headlight are definitely low, whether towing or not. It isn't enough to worry about, but I couldn't dazzle anyone with high beams if I tried - not that I would, but it is probably good that I can't. They probably do put out too much light anyway (-:
BTW, there is no side to side adjustment on mine, or I've never found it. They seem to assume that if they need re aiming side to side then you need to get the bodywork FIXED (-:
