F350 Trouble Towing Trails West
Last activity 2006-07-20 2:16 PM
19 replies, 6862 views
n2collies
Reg. Jun 2006
Posted 2006-06-25 8:23 AM (#43575)
Subject: F350 Trouble Towing Trails West
I recently purchased a F350 4x4 drw 6.0l diesel tow boss 4.30ls to pull my Trailers West 3hr 8x8 side tack LQ trailer. When I pull it the truck bucks and lunges sometimes SEVERLY! the truck dealer says trailer fault the trailer dealer and manufactur say truck fault all say air bags will solve problem. Can anyone tell me who is right and will it really solve that violent of a buck?
Edited by n2collies 2006-06-25 9:18 AM
brushycreekranch
Reg. Jun 2006
Posted 2006-06-25 9:22 AM (#43578 - in reply to #43575)
Subject: RE: F350 & Trails West
500100100100100
Is it doing it when the tranny is shifting? I had a 98 Dodge that did that if I did not let up on the gas way before the tranny shifted into higher gears. It turned out to be a problem with the Tow/Haul button. After living thru the nightmare for about 6 months. I went to the dealer with fully loaded LQ trailer in tow, loaded up the service manager and the tranny mechanic and drove over South Mt with their computer attached to the truck brain. An hour later, my "captives"  had all the info they needed at the exact moment it was doing it and ordered the "correct" part. That totally fixed my problem after the 5th time in the shop for the same problem.
you wrote:When I pull it the truck bucks and lunges sometimes SEVERLY
n2collies
Reg. Jun 2006
Posted 2006-06-25 9:47 AM (#43580 - in reply to #43575)
Subject: RE: F350 Trouble Towing Trails West
It's a automatic and very smooth so I'm not sure if it is sifting and I too have had "captives" from the dealer and they begged me to make it stop. They still say Trailer problem, grainery near me weight it and said tongue weight was 33% with nothing in the LQ(water etc) but TW swears it was less than 25% when it left. My big concern is if I put airbags and fill the trailer for a upcoming trip will I be ok of will my horses refuse to ever get in it again!
hav2ride
Posted 2006-06-25 10:54 AM (#43585 - in reply to #43580)
1000500100100
How big is your LQ and how much does the trailer weigh? I had this problem with my first LQ (29' box and very heavy) and my 350 dually. It turned out to be a combination of 2 things. The tongue weight was very heavy ( the LQ dropped the truck, which was a 4x4, on it's axles). I solved the problem by adding Super Springs. But the trailer still bucked occasionally. Ended up the one brake magnet was slightly off so it occasionaly made contact when it shouldn't, causing it to buck down the road. 4=star replaced the brake and it solved the issue. BUT!! If you do sink to the axles, you have too much tongue weight. Try that first.
Reg
Posted 2006-06-25 12:43 PM (#43587 - in reply to #43575)
2000500100252525
Originally written by n2collies on 2006-06-25 8:23 AM
Hi and Welcome to the Forum.
There are several threads dealing with Ford's "integrated" (but optional) brake controller, also ABS brakes and Prodigy controllers. If you search for those you might find similarities with your equipment configuration and symptoms.
Air bags (air springs) are a good idea anyway, but aren't the way to solve THIS problem. See other threads on air bags/springs.
n2collies
Reg. Jun 2006
Posted 2006-06-25 4:38 PM (#43595 - in reply to #43575)
The braking sytem seems to work fine, the violent bucking is happening when I'm driving done the road and rock in the road can start it.
rockyrider
Reg. Jun 2004
Posted 2006-06-26 12:35 AM (#43613 - in reply to #43575)
100100100
If you haven't done so yet, post your question on these forms. You  will get some straight answers from people that know. All too often the Stealership (both truck and trailer) try to blow you off, or flat out just don't have qualified people woking there who can solve the problem
http://www.ford-trucks.com/forums/showthread.php?t=502914
http://forums.thedieselstop.com/ubbthreads/postlist.php?Cat=0&Board=2003Drivetrain1
iCE CRM
Posted 2006-06-26 7:47 AM (#43619 - in reply to #43613)
It almost sounds like something is grounding out and making the brakes on the trailer surge off and on. Try unplugging the trailer on some place where there isn't much traffic and see if it still does it. I don't think the size of the trailer is the problem I used to pull a Sundowner 37' on box with air bags with F350 with air bags and 3:73 gears I didn't know that Ford had an opption of 4:38 on F350 I thought you had to go to F450? I thought it was a 4:10
TxCountryboy
Reg. Jun 2005
Posted 2006-06-26 8:07 AM (#43621 - in reply to #43575)
If you have the new 05 or 06 ford with the built in brake controller that could be causing it. I am not sure how, but I think your brakes are locking down anytime you barely tap your brakes or like the previous post said, something is ground out. I have a trails west gooseneck lq and i have never had a problem with mine. I also drive a 05 dodge dually. I HAD a 6.0 ford and had lots and lots of problems with it. Ford is real bad about not wanting to help customers. I have nothing but good to say about dodge. But i dont think the problems lies between the two makers. Check your built in brake controller if you one.
n2collies
Reg. Jun 2006
Posted 2006-06-26 8:11 AM (#43623 - in reply to #43621)
ok of curosity what kind of troubles did you have with your ford?
karol
Reg. Jun 2006
Posted 2006-06-29 10:54 AM (#43787 - in reply to #43575)
There are a lot of good responses here. My new trailer was doing the same thing. It had to be re-wired due to a wire to the brakes was wrong. May not be your problem, but the wiring could be an issue.
Mr. Trailer
Posted 2006-06-29 1:33 PM (#43794 - in reply to #43575)
We just got done dealing with a similar issue. It involved a 2006 Ford truck and a living quarters trailer – shaking pretty bad (jerking back and forth). It was worse when you were slowing down and nearing a stop. The customer was positive that it was the fault of the trailer. We tried several things on the trailer (to no avail) and then called Ford.
In this case, it took several calls and a good Ford dealer to physically inspect the truck, but it ended up being an easy fix. The Ford dealer replaced a chip in the truck that synchronizes acceleration and braking, and the problem was solved.
I can’t say that this is the case with your set up, but it is worth checking.
n2collies
Reg. Jun 2006
Posted 2006-06-29 3:32 PM (#43802 - in reply to #43575)
Today air bags were installed and later I'm going to make a test ride without any horses to see if indeed the problem has been fixed. if not tommorrow I will be at the dealer! I know it is not my trailer and I will keep arguing that issue-I pulled it with my trade-in on Mon and no problems then Weds with the new and oh boy was there problems... Quess next I'll have to prove to ford that there are no gremlins in my yard that messed with my trailer on Tues
SLICKRNSNOT
Reg. May 2006
Posted 2006-06-30 11:12 AM (#43832 - in reply to #43575)
Just returned from a conference and got some info on the 6.0.
This may be caused by VARIABLE GEOMETRY TURBO controll valve contamination.
IF THEY REPLACE THE VGT THEY MUST ALSO REPLACE THE TURBO SUPPLY LINE 3C3Z-9T516-BA
APPARENTLY IF THE TURBO LINE GETS CONTAMINATION IT STICKS THE TURBO.
SLICKRNSNOT
Reg. May 2006
Posted 2006-06-30 12:54 PM (#43837 - in reply to #43575)
Also.....there may be wire chafing special service message (SSM) 17961  the FICM harness can rub thru and cause bucks,jerks,low power.
deranger
Posted 2006-07-01 6:21 AM (#43856 - in reply to #43575)
5001001001001002525
Hello n2collies and welcome to the forum. Everyone has come up with good stuff so far and I'll attemp to add to the solution. If none of the "idiot lights" on your instrument panel are coming on when the problem is happening, that's a good thing. If any lights are coming on, the computer should be storing a code for the problem, but I don't think that is your problem.
If I were solving the problem, I would want you to take me for a ride in your rig and let me ride in the trailer. The first thing I want to know is if the trailer brakes are engaging intermitently to cause the jerking and bucking? If the brakes are coming on and going off rapidly, I'm going to be staring at your truck as the guilty party.
I think you've already elminated the trailer as the problem by towing the trailer with your trade in recently. Someone already mentioned the "stealership" as trying to avoid the problem and they will. My wife hates "stealerships" so much, that I can't let her take our truck in for service any more. The last time she was there was about a year ago and it got ugly, but she got results. Anyway, I think the truck is the problem and you need to stay on the dealer to make them fix it.  Happy trails.
jasonsthe1
Posted 2006-07-18 5:09 PM (#44984 - in reply to #43575)
I have a F350 Lariet Superduty and I also manufacture living quarters.
I haul all brands and sizes of trailers converted and not, I have had no problems what so ever with the ford. I also just purchased a Bully Dog power pup, WOW What a major gain in Power, torque and mileage.
MrTruck
Posted 2006-07-19 2:18 AM (#45016 - in reply to #43575)
10001002525
I've seen some 04 Fords with a vibration problem similar to jerking. It was solved by Ford service centers by shimming leaf springs to change the angle of the drive shaft connecting to the pinion shaft. But making it ride better loaded made it ride worse empty. On some F450/550's with jerking problems, Ford added a rear axle tracking bar.
When I talked to some of the Ford engineers this spring while at the 07 Sport Trac media launch, they denied knowing anything about it. Firing too many good engineers over the 2003 Power Stroke problem is still plaging Ford.
Next week I'll be in Oregon driving the 2007 Expedition EL (longer) I'll see what the latest fix is. Might even find out more on the 6.4L PS. The new Expedition will be rated to tow over 10,000 lbs. But I still morn the death of Excursion diesel.
SLICKRNSNOT
Reg. May 2006
Posted 2006-07-20 2:10 PM (#45143 - in reply to #45016)
Did you get in on the test drives at the Astoria Warrenton airport ?
MrTruck
Posted 2006-07-20 2:16 PM (#45144 - in reply to #43575)
10001002525
No I didn't, I saw the new Expedition in March but didn't get a chance to drive one.
