Generators
Last activity 2006-06-04 10:41 AM
22 replies, 6717 views
Allen
Reg. Dec 2004
Posted 2006-06-01 2:49 PM (#42505)
Subject: Generators
We have a cherokee tomahawk with living quarters
Our delima is;we have a coleman powermate 5000 we have a 30 amp cable coming from the trailer and we adapt to the 15 amp 110 plug on the generator and we keep throwing the breakers on the generator .
we run a coffee pot, 5 gal hot water heater and air conditioner and refrigerator. and the basic lights and small tv and pump.
the generator has 2, 15 amp plugs and 1, 120/240 20 amp plug.
any sugestions on what to do
we are even looking at buying a new generator
Dawnya
Posted 2006-06-01 4:15 PM (#42511 - in reply to #42505)
Subject: RE: Generators
1001001001002525
Is the water heater electric?  If so, they draw HUGE amounts of power.
Running that AND the AC may be your problem.  Not sure how much a coffe pot draws but with a heating element, it may be a lot.
Sounds like your just overloading the generator.  Try to run the AC and a few lights only and see how it does.
BigT
Posted 2006-06-01 4:20 PM (#42512 - in reply to #42505)
Simple solution, buy a generator that has a 110 volt 30 amp outlet. You are trying to run the whole trailer on 15 amps. If you continue to run the trailer on 15 amps, you could do damage to the AC and the fridge.
Posted 2006-06-01 4:22 PM (#42514 - in reply to #42505)
Your generator has two coils.  Each can generate 15 amps.  When you plug into one 15 amp receptacle, you get 15 amps or 1800 watts.  No more since the circuit breaker trips at 15 amps.
To get more watts of power from your generator you will have to have two 120 volt plugs (each a separate circuit) or a single 240 volt cord input to your trailer
Terri
Posted 2006-06-02 12:03 AM (#42533 - in reply to #42514)
200050010010010025
So if I'm understanding it right, each plug is 15 amps and if you use both plugs with an adaptor it is 30amps?  That is what those adaptors are for isn't it?  The one that plugs into both outlets and then goes to one plug the trailer power cord plugs into.
does that make sense?
Dawnya
Posted 2006-06-02 7:28 AM (#42537 - in reply to #42505)
1001001001002525
LOL!  I was gonna ask the same thing Terri.
The twist lock on our Kipor's is 30amp - right?  That's the one I've been using to run everything anyway, with no problems.
Edited by Dawnya 2006-06-02 7:29 AM
ASJ
Reg. Mar 2005
Posted 2006-06-02 7:42 AM (#42538 - in reply to #42505)
Hi, I know that they make a Cheater Box for 50 amp. It plugs into one 20amp and one 30amp plug on separate circuits to provide a 240v/50amp service outlet. So, surely they also make a service plug that will plug into both of your 15amp outlets on the generator and combine them so that you will have a single 30amp plug. If they can do it for the 50amp/240v they should have one for 30amp/120v.
Good Luck
Posted 2006-06-02 9:34 AM (#42543 - in reply to #42505)
If your generator has the 30amp RV plug. You can go to home depot or Lowes and buy a plug, a length of 10 guage wire and a box or recepticle of your choice that your trailer will plug into.  You buy all the parts for $20.
My Generac 6000 Watt generator has four 15amp plugs and one 30 amp plug.  Air Compressors on jobs sites keep popping the 15 amp breaker. Couldn't find a cheater box so I just made one up. Mine went from 30amp RV plug to a Four plex box of 110watt plugs.  Compressors works fine now.
Terri
Posted 2006-06-02 9:55 AM (#42547 - in reply to #42537)
200050010010010025
Mine doesn't have the 30amp plug, just 2 15 amp plugs.  I'll get the adapter and then see if we can run the a/c and microwave at the same time.
Posted 2006-06-02 10:26 AM (#42548 - in reply to #42533)
Originally written by Terri on 2006-06-02 12:57 AM
Not quite...  If you make an adapter that that plugs into both 15 amp outlets you'll be paralleling the two coils.  There is the great chance that one coil will be unbalanced to the other and have more load.  That's why the OP has a 20 amp outlet instead of 30 amps.  If you make this "two to one" adapter anyway, this will happen.  As you turn on appliances the current will be shared across the two coils.  At some point, one coil will hit 15 amps and its breaker will trip.  The other coil will suddenly have the full load and its breaker will trip immediately after.   This instantanous load is the hardest kind of overload to a breaker.  IF the last breaker doesn't trip, you WILL burn out the generator.
Terri:  You will be better served by having separate two cords.  Each cord will provide 15 amps to the appliances connected.
Allen:  It is better to get an adapter to your single 20 amp outlet from the 30 amp RV cord.   Make sure the adapter is wired to provide 120 volts.  A mistake will connect 240 volts ... and burn up a lot of cash and trailer appliances.
Edited by hosspuller 2006-06-02 10:35 AM
Allen
Reg. Dec 2004
Posted 2006-06-02 10:55 AM (#42549 - in reply to #42537)
Originally written by Dawnya on 2006-06-02 7:28 AM
So how do you
have the plug wired , are you only using half of the 220 or is your trailer wired for 220
Terri
Posted 2006-06-02 11:25 AM (#42553 - in reply to #42548)
200050010010010025
I just went and looked at my generator and it has a 30 amp socket.  I don't know why the RV place(we bought it with our 5th wheel) gave us an adaptor for a 30/15 amp instead of the correct 30amp to 30amp.   I'm gonna call them and ask.
Allen
Reg. Dec 2004
Posted 2006-06-02 11:53 AM (#42555 - in reply to #42505)
where in south texas are you from Elite
Terri
Posted 2006-06-02 11:59 AM (#42556 - in reply to #42555)
200050010010010025
I am south of Alice right now, but in a few weeks a job transfer is moving us to New Mexico.
Allen
Reg. Dec 2004
Posted 2006-06-02 12:11 PM (#42558 - in reply to #42505)
We are in pleasanton
what line of work are you in
Dawnya
Posted 2006-06-02 12:25 PM (#42561 - in reply to #42549)
1001001001002525
Originally written by Allen on 2006-06-02 10:55 AM
So how do you
My trailer is wired for 110 and wired just like a house going into a breakerbox and branching off from there.  Pretty much every appliance and outlet has it's own breaker.
There is one RV 30amp line coming out of the trailer that I twist lock on to the generator.  I didn't do all that (we added outlets), had a electrician do it and it works like a champ!
Dawnya
Posted 2006-06-02 12:28 PM (#42562 - in reply to #42553)
1001001001002525
Originally written by Terri on 2006-06-02 11:25 AM
You got a Kipor too didn't you?
Just get the twist lock adapter (30/30 male) and hook everything up to that.  Using the twist lock, I run the AC and fridge with smart throttle on and everything runs smoothly!
Terri
Posted 2006-06-02 4:24 PM (#42570 - in reply to #42558)
200050010010010025
I'm in the child rearing dept.  My husband works for the gov and that is who is moving us.
Terri
Posted 2006-06-02 4:29 PM (#42572 - in reply to #42562)
200050010010010025
Yea, I got the kipor and we have used it twice and it ran great as long as we remembered to turn off the a/c before we used the microwave.  Now that I know we were only using the 15 amp outlet and not the 30amp maybe it will run both.
Someday I may have my horse trailer wired so I can use the generator for that too.  I was supposed to have someone come out yesterday to do it, but wouldn't you know it, it rained.  And boy has it rained.  All the feed pans were running over, the stock tank is now full and the dump cart for my riding mower was almost full.  Its 16 inches deep!!
SLICKRNSNOT
Reg. May 2006
Posted 2006-06-02 5:20 PM (#42578 - in reply to #42505)
Got a Yamaha 2800i Dealer gave me an adaptor cord plugs in to the 30 amp plug on generator and works great!
maccwall
Reg. May 2004
Posted 2006-06-02 5:50 PM (#42579 - in reply to #42578)
500
Didn't have my adapter first time we used our generator and could only use the 15amp outlets (have 2 of those, used 1). Would run A/C and fridge at the same time but not my micro unless I shut off the air. Used it for the second time last weekend with the 30amp adapter and ran everything no problem. If yours is a Kipor 3500Ti it should have the 30 amp outlet on it. Talk to your dealer about getting an adapter.
Safe Riding,
Todd
Edited by maccwall 2006-06-02 5:58 PM
Terri
Posted 2006-06-02 7:49 PM (#42583 - in reply to #42579)
200050010010010025
I have the Kipor 3500Ti and it has the outlet on it.  I just never noticed it since the adaptor that came with it went to the 15amp outlet.  I'll have to get the other one.   I'm glad to hear it runs everything and can't wait to get my trailer wired.
efaubert1
Posted 2006-06-04 10:41 AM (#42610 - in reply to #42505)
50010025
If you want to run it properly, take the plunge and buy a generator that has a NEMA 30 amp plug, get the adapter cord and plug it in. I also have the Kipor 3000TI, and it runs ALL the appliances just fine off the 30 amp plug. Note: The Kipor 3500TI and Kipor 3000TI mentioned are one and the same generator, just new nomenclature.
