Best fly spray and or sheet
Last activity 2006-05-10 9:49 AM
6 replies, 4742 views
Reg. Dec 1899
Posted 2006-05-03 4:09 AM (#41225)
Subject: Best fly spray and or sheet
My horse has very little tail. I have been told vinagar mixed with a oil fly spray works the best. Has anyone used this? Also I 've got a fly sheet but it seems very hot.. I am in Texas...HOT. Fly sheets I see do not ever say light in ths ads.
Anyone have a very light sheet and who makes it?
terri s
Posted 2006-05-03 9:09 AM (#41237 - in reply to #41225)
Subject: RE: Best fly spray and or sheet
500100100100
I have that same problem here in Kansas. I like pretty much everything Weatherbeeta makes, but probably had the best luck with the Saratoga. Not only was it the cheapest one I bought, it also held up to the abuse better and seemed cooler for the horse.
kickshaw44
Reg. Dec 2005
Posted 2006-05-03 11:02 AM (#41245 - in reply to #41225)
I am in Georgia, and we have a very similar problem here. I do not like the fly sheets. All of our horses have them, but we never use them, 'cause it just makes them SWEAT!!!! (they are LIGHT, but made out of plastic-like material....plastic + humidity = one wet horse!) I have found that if you will mix avon skin so soft with some fly spray or vinegar with fly spray that it works really well. There is also a recipie that calls for dawn dish soap, skin so soft and vinegar - but I'm not sure of the parts of each. I have also fed vinegar in the feed, so when they sweat it comes out through their pores.  (when the vinegar sweats through, they don't stink. Of course if none of the above work, you could "make" him a tail. In the saddlebred world, it is a common occurence to cut all but a foot or so of tail off in order to make a switch. To help out these horses, I have seen hay strings tied together and then tied into a braid in the tail. (Of course you wouldn't want the hay strings dragging the ground :)
Edited to say: I had heard of feeding garlic for the same reason as vinegar, but FORGET THE GARLIC THING - thanks aznewguy!
Good Luck and Keep us Updated!!
Edited by kickshaw44 2006-05-04 10:45 AM
AZ_newguy
Posted 2006-05-03 4:36 PM (#41266 - in reply to #41225)
Please Google 'garlic equine hemolytic anemia' before you feed your horse garlic.
kickshaw44
Reg. Dec 2005
Posted 2006-05-04 10:40 AM (#41295 - in reply to #41225)
aznewguy,
Thanks for the suggestion - I have never heard of that before - makes me glad that I haven't fed garlic!!!!
jackbrat
Posted 2006-05-10 2:10 AM (#41524 - in reply to #41245)
500100
hounddog
Reg. Dec 2005
Posted 2006-05-10 9:49 AM (#41535 - in reply to #41225)
1000100100
Old fashion oil based REPLX and a sponge.I do use the REPLX that is water soulible mixed in a 2 gallon tank sprayer but like the OLD forumal the best.Tried others and returned to the old original.
