electric/hydraulic brake controllers
Last activity 2006-05-02 3:54 PM
17 replies, 5475 views
hav2ride
Posted 2006-04-25 3:39 PM (#40916)
Subject: electric/hydraulic brake controllers
1000500100100
Anyone know of a good controller, preferably digital and simple to use!!, that works on electric/hydraulic brakes?
Reg
Posted 2006-04-25 4:30 PM (#40919 - in reply to #40916)
Subject: RE: electric/hydraulic brake controllers
2000500100252525
Originally written by hav2ride on 2006-04-25 4:39 PM
I have the Tekonsha model that is one below the Prodigy, based on a recommendation that electric over hydraulic systems don't like the pulsing of the Prodigy. I've beeen happy with it, though if I was doing it again I would look for something with digital settings - just for easy to re-gain settings for different loads and different trailers.
I'm still not remembering the model name, maybe later. I'll try to remember to make a note of it the next time I'm in the truck.
mgisse
Reg. Dec 2005
Posted 2006-04-25 5:46 PM (#40921 - in reply to #40916)
Primus and Voyager from Tekonsha both will work. The Primus has a digital readout.
hav2ride
Posted 2006-04-25 6:28 PM (#40924 - in reply to #40919)
1000500100100
You have a Voyager. I had one before and, while they are good ones, I always had a hard time getting it set up for 2 different trailers. We have no place nearby that is actually level and long enough to set and test it and with 2 trailers, one monster and one 2H BP, I felt it was a major pain in the butt!
hav2ride
Posted 2006-04-25 6:29 PM (#40925 - in reply to #40921)
1000500100100
I'll check the web for Primus. Thanks!I just checked the web site on Primus and it never mentions electric over hydraulic brakes. Are you sure it works with them? I did see one called Hayes-Lemmerz Genesis wchich says is works with E/H brakes. It looks like it is simple to use but I have never heard of that brand.
Edited by hav2ride 2006-04-25 6:42 PM
Terri
Posted 2006-04-25 9:10 PM (#40936 - in reply to #40925)
200050010010010025
I have had 2 Hayes controllers.  The first I had no problems with, my new one I just had installed.  BUT, I don't have hydraulic brakes.  Just electric.
horsey1
Reg. Dec 2004
Posted 2006-04-26 9:05 AM (#40951 - in reply to #40916)
Might want to check with your E/H unit's manufacturer. Different ones seem to recommend different controllers. I know I've seen some that accept the Prodigy, and some don't. On those that do, the Prodigy is nice because the "boost" feature gets the E/H unit spooled up quicker for action. I've used a Prodigy on the new Dexter unit & it worked well.
H1
hav2ride
Posted 2006-04-26 9:43 AM (#40953 - in reply to #40951)
1000500100100
I have a Prodigy now but Tekonsha says it will not work with electric over hydraulic. (what a shame!!) I called a brake controller distributer and talked to them. They highly recommended the Genesis. I know the Voyager is what many people use but it is just such a pain to change back and forth for different weight trailers! I love the self leveling and digital systems!
Reg
Posted 2006-04-26 8:32 PM (#40967 - in reply to #40916)
2000500100252525
I have the Voyager on the truck and the Primus on the Durango.
The only reason for this is the sequence that I bought things in.
Since the truck is used for either trailer it makes more sense to have the Primus on that vehicle, the Durango can only pull the b/p (obviously).
So, I'll probably swap them around to get the more easily repeatable settings in the vehicle that tows the most variations. I'll report back on how the Primus works with (or against) the Carlisle pump.
hav2ride
Posted 2006-04-27 7:36 AM (#40981 - in reply to #40967)
1000500100100
Well after much internet searching and many phone calls to Elite, Carlisle, and a brake controller distributer, I ordered the Hayes-Lemmerz Genesis model. It is the one that Carlisle says will do the job for me. On the brake controller distributer web site, I found a section that fully explains the differences between brake controller types and found that the inertia type, like Voyager, are not really recommended for hilly areas. No wonder I hated mine!!! BTW, I talked with Tekonsha and the only one that they recommend for electric over hydraulic is the Voyager. To bad they don't get the Prodigy working for both brake types. I loved my Prodigy.
Edited by hav2ride 2006-04-27 7:38 AM
Terri
Posted 2006-04-28 11:20 AM (#41030 - in reply to #40981)
200050010010010025
What is the web site?
hav2ride
Posted 2006-04-28 2:27 PM (#41036 - in reply to #41030)
1000500100100
I'm assuming you mean the site for the contollerrs? www.brakecontroller.com
Terri
Posted 2006-04-28 6:21 PM (#41050 - in reply to #41036)
200050010010010025
Yep that's the one.  Thanks.
Kay
Posted 2006-04-29 12:01 PM (#41065 - in reply to #40916)
50025
There is an adapter available that enables the Prodigy to be used with electric hydraulic brakes.  It is about $85.  It was necessitated when Ford came out with the built in brake controller.  Guess what it is?  It's a Prodigy in Ford clothing!!  We are selling quite a few of them.
hav2ride
Posted 2006-04-29 5:17 PM (#41074 - in reply to #41065)
1000500100100
I had heard about the adapter but decided it just made more sense to go with the Hayes-Lemmerz, cost wise.
hav2ride
Posted 2006-05-02 7:33 AM (#41186 - in reply to #41074)
1000500100100
Finally got the new controller on the truck and drove both the little 2H and the big LQ. The controller is fantastic! Simple to set and provides a smooth, consistent stop for both the electric and the electric over hydraulic brakes. I highly recommend Hayes-Lemmerz.
Terri
Posted 2006-05-02 8:35 AM (#41189 - in reply to #41186)
200050010010010025
which model did you get?
hav2ride
Posted 2006-05-02 3:54 PM (#41208 - in reply to #41189)
1000500100100
I got the Genesis. The only complaint I have is that the digital display is not as bright as the Prodigy but it is still nice to have a digital!
