Needed to buy/find
Last activity 2006-05-02 2:37 PM
6 replies, 4418 views
Paints
Posted 2006-04-25 9:24 AM (#40905)
Subject: Needed to buy/find
We're looking for trailer-aid for our 2 trailers is used to change tires in case of flats.Thanks much for help.
Terri
Posted 2006-04-25 9:51 AM (#40906 - in reply to #40905)
Subject: RE: Needed to buy/find
200050010010010025
You can get them frome catalogs like Valley vet, Jeffers, country supply sometimes e-bay has them and I think I saw them at the local Tractors supply store.
ISHOM
Posted 2006-04-25 11:05 AM (#40908 - in reply to #40905)
I ALWAYS carry blocks of wood in my truck when I haul.....used for dollying the trailer down, chocking the tires, blacking the horses feet (put the feet on to keep grass off of hoof black) etc.....  Why spend the money for a trailer aid when you can ramp the trailer onto 1 X4's and use another one as a ramp.....?Much cheaper and the wood can be multi used.
"Build it and they will come" ????
Edited by ISHOM 2006-04-25 11:08 AM
longearsrule
Reg. Apr 2006
Posted 2006-04-25 12:02 PM (#40909 - in reply to #40908)
100100100
A friend made a deal for me made out of 3 pieces of wood, each longer than the other, stacked. The ends are cut at an angel to drive up on. I use it to level the trailer, but could be used to change a flat also. Even have a little handle to carry it with. It's pretty handy
cowgirl98034
Reg. Apr 2004
Posted 2006-04-30 6:25 PM (#41115 - in reply to #40909)
That is exactly what I did... I took a 16" long  2x6, a 10" long 2x6 and then a 6" long 2x6, glued them together and covered with composition rolled roofing, so there was no slipping.  In the end it looked like a little set of steps you could walk up one side and back down the other.  I have changed flat tires on the trailer without having to unload; just drive onto it.  Very handy and cheap too!
Reg
Posted 2006-04-30 7:58 PM (#41121 - in reply to #41115)
2000500100252525
I was lucky enough to score several LVL off-cuts about 14 inches wide, FULL 2 inches thick and as much as 4 ft long. With a triangular rubber wheel chock I can improvise a wheel changing ramp that is a LOT steadier than the little plastic things, MUCH less likely to sink in a soft shoulder, etc.
They are great for landing gear pads and packing up one corner of a ramp if I have to load/unload on very uneven ground.
j&j
Reg. Oct 2005
Posted 2006-05-02 2:37 PM (#41203 - in reply to #40905)
Subject: RE: Drive-on trailer aid
I have a cut off from a 6" x 6" (about 2 1/2' long)that I beveled on both ends. Can drive up right on it and raises the other tire enough to change it.
Cost = $0.
Edited by j&j 2006-05-02 2:41 PM
