Battery acid on trailer
Last activity 2006-04-22 2:48 PM
5 replies, 3819 views
longearsrule
Reg. Apr 2006
Posted 2006-04-20 8:02 PM (#40757)
Subject: Battery acid on trailer
100100100
Hi, I am new to this site, it is great, very addictive.
Anyway, problem is I bought a used trailer with bad batteries and they boiled over when I hooked it up to electricity and the acid ran down the front of the trailer. Any suggestions on how to clean it up? Thanks!
xyzer
Reg. Apr 2004
Posted 2006-04-20 10:35 PM (#40762 - in reply to #40757)
Subject: RE: Battery acid on trailer
Originally written by longearsrule on 2006-04-20 8:02 PM
Wet down the area and sprinkle baking soda on it. It will nuetralize the acid.
Reg
Posted 2006-04-21 8:29 PM (#40808 - in reply to #40757)
2000500100252525
Originally written by longearsrule on 2006-04-20 9:02 PM
Hi and welcome.
I doubt that the batteries "boiled".
It is more likely that they were topped up before charging and overflowed.
It is a common mistake to fill a flat battery and then charge it.
Anyway, hose it off well and you should be all done.
Baking soda if it makes you feel better about neutralising the acid, but it isn't necessary if you hose it off well.
paintthatain't
Posted 2006-04-21 10:07 PM (#40811 - in reply to #40757)
Water will only was the acid off it won't stop the chemical reaction that has already started. One of the best ways to treat battery spills is to make a paste of bakingsoda and water. Just smear it on and let it sit a while. Then flush the area well with clean water. If it's on a painted surface it may need a quick poof can job immediatly to keep it from rusting.
Just my .02,   CS
longearsrule
Reg. Apr 2006
Posted 2006-04-21 11:06 PM (#40812 - in reply to #40811)
100100100
I did the baking soda thing, twice. It is on aluminum, can it be buffed out someway also?
Don't know if they were over filled or what, I didn't do anything to them except to plug the trailer in to charge them up. Sure messed up a nice trailer. New batteries are doing fine. Thanks for the input.
Reg
Posted 2006-04-22 2:48 PM (#40822 - in reply to #40812)
2000500100252525
Originally written by longearsrule on 2006-04-21 12:06 AM
In the hour or more that it took you to post here, get a response and execute it - the acid was essentially GONE, i.e. the reaction had run it's course.
Spattering baking soda on the area initiated a new reaction (Alkali on Aluminum), so you probably now have more mess than if you had just hosed it off. I don't remember which salts of aluminum turn the surface black or white. For mere APPEARANCE you can probably do a fair/good job by brushing it out with a stainless steel wire brush or FINE stainless steel wire wool (and elbow grease). Stainless brushes are cheap at a local welding supply shop, they're probably one of the cheapest items there. AVOID regular steel brushes or "Brillo" pads.
