CB's
Last activity 2006-04-18 8:35 AM
10 replies, 4927 views
Lurker
Reg. May 2004
Posted 2006-04-17 2:20 PM (#40555)
Subject: CB's
Just wondering what kind of CB's everyone else has.  I just have a basic cobra model now and was looking to upgrade to something with a little more range. Any recommendations?
xyzer
Reg. Apr 2004
Posted 2006-04-17 2:24 PM (#40556 - in reply to #40555)
Subject: RE: CB's
Originally written by Lurker on 2006-04-17 12:20 PM
All (almost all) CB's are FCC regulated to tranmit a max of 4 watts. Some handhelds output less. If you want to improve range the best way is with a good antenna and where you mount it.
jdzaharia
Reg. Apr 2006
Posted 2006-04-17 2:46 PM (#40561 - in reply to #40556)
Subject: RE: CB's
1001001001002525
Xyzer's right.  It is all about antenna quality and placement.  The further you can get an antenna from a large flat surface of metal, the better.  Pickup cab roofs, and similar surfaces are bad for CB reception.  It sounds funny, but I know somebody who drastically improved their reception by relocating their antenna from the roof of their pickup to the backrack/rear window protector.  Did you ever notice how a lot of semi trucks have the antennas pointed at an angle forward, away from the cab?  That is the reason.  The only problem with really good antennas, is sometimes they get quite long.  I had a 9 foot whip for a while.  The range was awesome, but it would hit stuff quite a bit, and I had to latch it down when parking in the garage and going though fast food drive-thrus.
Lurker
Reg. May 2004
Posted 2006-04-17 2:51 PM (#40562 - in reply to #40555)
Subject: RE: CB's
Yea guess I am limited with the antennas.  The guy who owned the truck before me had a long whip antenna mounted to the rear corner of the bumper.  I pull a gooseneck trailer 90% of the time so that option is out.  Currently I have it mounted to the side rail of the pickup bed just behind the drivers side.
maccwall
Reg. May 2004
Posted 2006-04-17 7:21 PM (#40593 - in reply to #40562)
Subject: RE: CB's
500
I have a small Cobra 25 with an after market amp that is intenal in the CB. It's not a powerful linear amp but it's suffices my needs. I have an 6' Firestick adjustable antenna drivers side behind cab mounted to the bed which is actually is not a very good place to mount an antenna.(Mirror would be better).
CB's are not plug and play items, there are alot of variables that play into reception range and transmission power of a CB. The biggest is the SWR adjustment. Antenna placement, condition of cable, terrain, weather. Since I'm not very good at explaining things, this web site should do the trick: http://www.firestik.com/Tech_Docs.htm it should be very helpful.
Hope it helps.
Edited by maccwall 2006-04-17 7:26 PM
RollinPonies
Posted 2006-04-17 8:06 PM (#40595 - in reply to #40593)
Subject: RE: CB's
CBers,
I haven't had a CB since 1978.  Never go anywhere without my mobile phone these days.  I am very interested in what you use the CBs for. I assume that it is to keep communication open in areas without cell coverage. Can you elaborate for me? I might need to look into another toy.
Thanks.
roll on
hounddog
Reg. Dec 2005
Posted 2006-04-17 8:08 PM (#40597 - in reply to #40555)
Subject: RE: CB's
1000100100
Bought a Midland 35 years ago.I hook a external speaker to it and it still works great.
Broken Bit
Posted 2006-04-17 8:09 PM (#40598 - in reply to #40555)
Subject: RE: CB's
Here's what ya need buddy,
  Go to your local radio shop and get ya a good Galaxy, they are top notch radios.  You can get some with built in linear's or boosters, take mine for instance... 40Watts output... oh yeah, baby, I don't like to repeat myself!  You can hear this cow truck comin' long before you can see me.  It even has custom blue lights installed in the face.  Built in "echo board" with reverb and talk back.  Go with Wilson Trucker SW-2000 antennas, duals if ya can, one on each mirror is my favorite set up, on the big truck and my pick-up.  Don't forget, no less than 18 ft. of coax between your radio and the antennas. and don't "coil" the excess all together it will cause a "choke" in the coax. Use RG/59 coax.  I like the clear sheath on the silver or gold braided cable just cause it looks good.  A good radio will have a built in SWR meter--use it-- make certain and "match" or tune your antennas to your radio and coax!  And to top it all of spend the $50-60 and get yourself a good Astatic 636-L mic.  Don't get a power mic.  You won't regret it and if you're gonna splurge on all the rest, the mic. is gonna be the least of your costs, but will make ya sound like a Professional Truck Driver....whoop whoop!!!  Be prepared to spend about $500.oo but it's worth it!!  You'll be runnin' with the big boys in no time.  Serioulsy, though I'm not trying to brag or be cocky, but with that electronic stuff you realy do get what ya pay for, so if you're gonna use it a lot and want it to do ya a good job, spend some money and get quality stuff.  That's my real suggestion.
Edited by Broken Bit 2006-04-17 8:11 PM
Lurker
Reg. May 2004
Posted 2006-04-18 7:48 AM (#40615 - in reply to #40555)
Subject: RE: CB's
Thanks or the response/suggestions. The CB I have now was given to me as a gift and I have really enjoyed having it, especially since I am on the road every weekend.  I will probably go down to the local store and see what kind of antenna set up and placement they recommend with my truck and trailer.
Dawnya
Posted 2006-04-18 8:17 AM (#40618 - in reply to #40555)
Subject: RE: CB's
1001001001002525
I have a Cobra 75wx and a 3' Firestik.
Just want to get weather and traffic.
Edited by Dawnya 2006-04-18 8:18 AM
hav2ride
Posted 2006-04-18 8:35 AM (#40620 - in reply to #40595)
Subject: RE: CB's
1000500100100
I use my CB to find out about traffic and road conditions, find truck stops, reroute directions, yada yada. Cells can't do that. I would never haul long distance without one!
