Securing a Generator in a Truck Bed
Last activity 2006-04-17 11:23 AM
4 replies, 4114 views
Dawnya
Posted 2006-04-16 6:48 PM (#40514)
Subject: Securing a Generator in a Truck Bed
1001001001002525
And keeping vibration down.
Any ideas?  This generator will 'permanently' stay in the back of the truck.
Posted 2006-04-16 7:02 PM (#40517 - in reply to #40514)
Subject: RE: Securing a Generator in a Truck Bed
Give us some idea of what else you will use the bed for? Do you want to enclose it and protect it from the weather/thieves? Or leave it open?
I assume you will mount it at the front of the bed, so it doesn't interfere with hooking up  your Gooseneck ( if you have one).  I'd probably place it next to one side or the other, So I could fuel it with climbing in the bed.  So for me it would be on the same side of the truck as the fuel door for the truck.  I'd also raise it off the truck bed high enough to make draining the oil out of easy.  So generators will drain the oil while sitting flat. Others need to be tipped in order to get the old oil out. So your mounts MAY need to be easy to remove every time you change the oil.
I would probably mount it on a piece of heavy plywood or steel plate that was mounted on some rubber grommets or maybe even springs.  You might take an floor mat and cut it to shape an place a couple layers of it under the plywood.
There are a number of ways to do it, depending on your skills and what material you access to. Of course a steel plate would be more durable, Plywood would have to be replaced periodically.
robdnorm
Posted 2006-04-16 9:43 PM (#40524 - in reply to #40514)
500
Have you considered locating this inside a tool box.  I am not referring to the ones that mount on top of the bed.  I am thinking about the ones that sit on the bed of the truck.  I have one in my F-250 and am able to a large amount of gear.  This would allow you to conceal the generator.  Now you have to cut a hole for this to vent the exhaust.  This will also give you room to store your gas tank.  I think there are units similar to what I am describing that are already wired and set up and have the outlets on the box.
Dawnya
Posted 2006-04-17 8:18 AM (#40531 - in reply to #40514)
1001001001002525
I don't use the truck bed as a truck bed, just for the trailer (gooseneck)
It's currently next to the cab on the passenger side so I don't have to get in the bed at all to hook-up or start.
I'd like to *permanently* bolt it down (take it out for servicing) as it will probably never need to be taken out otherwise.
I'd also like to leave it as low-profile as possible.  I'm afraid to put it in a box because, in Texas "surface of the sun" - it was 95* yesterday, Easter!  How's that for spring weather.  ugh.
Summit2
Reg. Jul 2005
Posted 2006-04-17 11:23 AM (#40545 - in reply to #40514)
We have a 4 hrs gooseneck, one ton dually, my husband had a box made to fit in the front of the bed of the truck, from side to side, three compartments.  The middle one was made to fit the generator, all three boxes have locks with tops that lift and the middle one also has the front that slides right out so when the generator is running we can keep the top down but have the front out for ventilation. Don't know how it would fare in your heat, we're lucky to get to the mid 80's for a stretch of more than a week and it still cools down at night.  Good luck.
