98 GMC
Last activity 2006-03-08 9:45 PM
3 replies, 3088 views
Jed
Reg. Mar 2006
Posted 2006-03-07 1:01 PM (#38384)
Subject: 98 GMC
I have a 98 GMC K1500. After a considerable amount of time rolling around on the floorboard, I have failed to find the wires to my brakelight switch. I'm trying to tie in the brake controller, and it says I need to find the "cold" side of the switch, no problem if I could just find the wires. Does anyone know what color they are and where I could find them other than right at the switch itself???
 Rollin on the floorboard till I find help!!!
xyzer
Reg. Apr 2004
Posted 2006-03-07 1:17 PM (#38385 - in reply to #38384)
Subject: RE: 98 GMC
Maybe they used a preasure switch at the master cylinder under the hood..?! Ford had one under the truck in the 80's
Edited by xyzer 2006-03-07 1:19 PM
Reg
Posted 2006-03-08 4:05 PM (#38469 - in reply to #38384)
Subject: RE: 98 GMC
2000500100252525
I don't know the answer to your question, but suggest you try the truck forums.
I think the last vehicle I had that actually had a a physical switch on the brake pedal's arm was a Volvo - I only mention this as a sure bet that GM would be as different as possible in details like this.
I think the other end of the wire you seek probably goes to some relay and flasher circuit before becoming the final brake light signal - FWIW.
Jed
Reg. Mar 2006
Posted 2006-03-08 9:45 PM (#38497 - in reply to #38384)
Subject: RE: 98 GMC
Hey Folks,
Thanks for the ideas. I'll try posting in the truck area.
