Pickup truck bed water tank
Last activity 2006-03-03 10:21 AM
5 replies, 6147 views
ddkrueger
Reg. Dec 2003
Posted 2006-03-01 6:38 PM (#38065)
Subject: Pickup truck bed water tank
I have a 2005 F-350 crew-cab with an 8 foot bed and I am looking for a water tank that would fit in the bed of my truck  and still allow me to haul my 4- horse gooseneck trailer.  Does anyone know of any websites that would carry polyethlyne  FDA approved water tanks?  I am looking for a 60 or 70 gal. tank.
Posted 2006-03-01 8:44 PM (#38071 - in reply to #38065)
Subject: RE: Pickup truck bed water tank
Do a google search on Plastic water tanks.  My search turned up SEVERAL HUNDRED sources of plastic water tanks.
Here is one http://www.tank-depot.com/drawing.aspx?dwg=Ace/SP0068-RT.pdf
68 gallon tank for $167
Aspen
Posted 2006-03-01 9:08 PM (#38074 - in reply to #38065)
I got a 50 Gallon White plastic one that fits in the back of my Pick-up at our Farm & Fleet in Wi. If you don't have one or something like it, Check out your feed store maybe they can order you one.
Yippee Ki Yo
Posted 2006-03-01 9:43 PM (#38075 - in reply to #38065)
Scroll down we are looking down this one, but would like to find it locally.
 "NEW! Pickup Truck Bed Water Tank w/63 gallon capacity (60 1/4"W X 21"L X 18"T) with built-in storage box!"
http://www.horsetraileraccessorystore.com/watertanks_accessories.htm
pegasus
Reg. Mar 2005
Posted 2006-03-02 10:06 AM (#38095 - in reply to #38065)
just a suggestion.. check with a local ag coop, they may be able to order a tank the right size and shape from their supplier of poly fertilizer tanks. I work for our coop in the fert/chem division and found, in the supplier catalog, just the 50 gal tank that would fit perfectly under the gooseneck, beside the hitch . They put the bung where I wanted it and fitted a small banjo valve and for around $75. We special order parts for our farmers and your coop may, too. Worth a try. I also got an demand water pump (just like the LQ one) and had it wired to easily connect to my trailer marine battery. I can gravity flow water or pump water, depending on what I need. Sure is handy.
CJ_Nebraska
Reg. Oct 2005
Posted 2006-03-03 10:21 AM (#38189 - in reply to #38065)
I'm considering the half-moon one from High Country Plastics.  Will probably purchase through ValleyVet.com as they're close and I've had good luck with them.
