Tankless water heaters
Last activity 2006-02-23 8:52 PM
8 replies, 5353 views
Zipitude
Posted 2006-02-22 7:52 AM (#37666)
Subject: Tankless water heaters
Has anyone tried using one of those tankless instant water heaters? If so, what brand? Was it a permanent mount or a portable camping unit? If permanent, how did you mount and vent it? I am trying to figure out what I want in my LQ, and the idea of having an endless supply of hot water sounds great!!! Any thoughts and suggestions would be appreciated.
huntseat
Posted 2006-02-22 8:34 AM (#37668 - in reply to #37666)
Subject: RE: Tankless water heaters
1000500100100100100252525
I have one in the barn and I will NEVER go back to the older tank kind.  Mine runs on gas so I'm not sure how you'd get it in a LQ.  I'd be asking this question on an RV website.
terri s
Posted 2006-02-22 9:33 AM (#37669 - in reply to #37666)
500100100100
I also have one in my barn, but it is an electric unit, so could easily be stowed in/under a cabinet and only plugged in when you need it. Probably have better ones at an RV place as far as size, but I just got mine at Lowe's.
Flooper
Posted 2006-02-22 2:23 PM (#37687 - in reply to #37666)
I just have the little old portable Coleman Hot Water On Demand...and I love it. I use it in the back of my trailer with a cut-down washtub for a shower floor. It puts out lots of hot water, and I can take it anywhere. Also use it for giving the horses a warmer bath when water from faucet would be a tad too cold. Also works great for washing dishes, hands, etc. One little propane cannister (the little 16 oz green ones) makes 40 gallons of hot water...and you can go from cold to nicely warm to burning hot with the unit. You can also get adapters to hook it up to larger propane tanks, and to hook it directly to a water hose. Like I said...I love mine.
rose
Posted 2006-02-22 4:37 PM (#37696 - in reply to #37666)
10005001002525
Have an electric tankless water heater in our house. It is wonderful. Got it from a dealer in Louisiana; dasudist@msn.com
The toll free number is 866-384-0500; Darrell or Roxie
The unit in our house is about the size of a brief case and hangs on the wall. It is one of the best things we've done to this house.
horsin around
Reg. Jun 2005
Posted 2006-02-22 10:11 PM (#37701 - in reply to #37666)
100100100
I thought about doing the same thing myself.  I found one at Menards and then someone told me they don't recommended them in campers.  I figured when I get serious about replacing my electric hot water heater, I'd call the company and ask.  The price wasn't too much different from putting in a gas hot water heater.
jack23015
Posted 2006-02-23 6:30 AM (#37709 - in reply to #37666)
We have a tankless heater in our cabin, and it works great. However, it demands 220 electrical service. Are there electric tankless heaters that work off of 110? I'm sure watts and volts figure in there somewhere. I would be interesred in a 110 unit for the barn. Some friends of ours have a portable propane heater from Zodi and it is great for camping.
Zipitude
Posted 2006-02-23 8:07 AM (#37712 - in reply to #37666)
There are some made for RVs, and they slide in just like the regular RV 6 or 10 gallon heaters and run on propane with a 12 volt hook up for the igniter. These units are very pricey!! About $875-950. I have found several of the other home style, and a lot cheaper, and the smaller LP versions say they can be used for camping, but their info was limited. I'm not sure if they were meant to be used outside or permanently mounted inside. The other thing about mounting inside is the space around the heater, nothing can be very close. That could be a problem, space wise, not to mention a fire hazard.
Dawnya
Posted 2006-02-23 8:52 PM (#37736 - in reply to #37666)
1001001001002525
I'd love to have one in the LQ but do they suck power!!
