Sundowner wiring question
Last activity 2006-04-21 7:06 AM
8 replies, 12787 views
nclabtech
Posted 2006-02-20 6:56 PM (#37566)
Subject: Sundowner wiring question
I have a 98 Sundowner Valuelite 2 horse GN. The trailer wire that plugs into the truck was severed and spliced by the previous owner. I would like to replace it but need to know what guage wire to buy? Thanks
Posted 2006-02-21 12:06 AM (#37594 - in reply to #37566)
Subject: RE: Sundowner wiring question
Sundowner uses a 6 conductor 14 gauge cable.
Their wiring code is:
Brown......Marker & tail light
Red.........Brake
Blue.........Aux lights
Green.......Right Turn signal
Yellow......Left Turn signal
Black........Ground
nclabtech
Posted 2006-02-21 9:44 PM (#37653 - in reply to #37566)
Thanks for the info. Where's the best place to purchase the replacement wire?
Rander
Reg. Mar 2005
Posted 2006-02-23 11:15 PM (#37738 - in reply to #37566)
Champion Trailer Parts Supply sells pre-made 6 wire whips with the trailer end plug mounted and 8 feet of 6 wire cable.
http://www.championtrailers.com/TRAILER_WIRING.htm
Bgdddyrch
Posted 2006-04-20 11:23 AM (#40728 - in reply to #37594)
Hosspuller,
Where did you get this from? It does not match anything I can find.
Yours says red is for the brakes. I have a red and I don't see that on any diagrams. you don't show power on your diagram. Isn't the center post 12V? I think it is the blue wire.
Terri
Posted 2006-04-20 1:37 PM (#40739 - in reply to #40728)
200050010010010025
the Aux wire is the 12volt wire.
RideAPaint
Reg. Oct 2005
Posted 2006-04-20 10:49 PM (#40764 - in reply to #37566)
It should be 14 ga. wire, but the color code varies with different mfg. Our Hawk uses blue for brakes, but the red wire is used for the left turn signal.
I would suggest contacting Sundowner, or get out the battery charger and see what lights up when you connect the wires.
Posted 2006-04-20 11:29 PM (#40767 - in reply to #40728)
Originally written by Bgdddyrch on 2006-04-20 10:23 AM
Hosspuller, Where did you get this from? It does not match anything I can find. Yours says red is for the brakes. I have a red and I don't see that on any diagrams. you don't show power on your diagram. Isn't the center post 12V? I think it is the blue wire.
Sundowner has their manuals on line.
Here's a link. ..http://www.sundownertrailer.com/login.php
You do have to register.
Bgdddyrch
Posted 2006-04-21 7:06 AM (#40773 - in reply to #40767)
Hosspuller, thanks. Now that you say the blue or AUX is for 12V I think that yours matches mine. I'll try it out tonight.
Thanks
