Oil bath trailer bearings
Last activity 2006-02-21 10:32 AM
6 replies, 11923 views
TKS
Posted 2006-02-20 8:54 AM (#37528)
Subject: Oil bath trailer bearings
I have been a long time reader and now want to ask a question. Does anybody use the oil bath lubricated trailer bearings? I have seen a setup for boat trailer hubs and I was wondering if this has shown up in the horse trailer industry.
Thanks
Reg
Posted 2006-02-20 9:06 AM (#37529 - in reply to #37528)
Subject: RE: Oil bath trailer bearings
2000500100252525
Originally written by TKS on 2006-02-20 9:54 AM
Thanks
Hi and welcome to the Forum.
I've thought about it, looked at them, priced them, thought about it some more.
I had HOPED that the only thing needed would be the outer cup, but most of the kits I've seen include the whole bearings and seals set, some require a different hub/brake_drum.
For what you pay and what you get I think they're not worth the money.
Grease works well and is still there if you are unfortunate enough to somehow lose the outer cap. With routine maintenance regular greased bearings shouldn't fail in many years and I don't think the mileage I do would ever be enough to make net savings from lower drag.
TKS
Posted 2006-02-20 9:52 AM (#37531 - in reply to #37528)
Thanks for the reply.
I agree with your assessment. I am a Mobil lubricant engineer and with the synthetic grease you can rest easy with an annual grease packing. However Mobil makes a synthetic semi-fliud that is used in oil bath trailer hubs that have leaky seals and it works geat. It is called Mobilith SHC 007. I think that if it became cost effective to have an oil bath bearing lube system for trailer bearings I would definitely change.
Kay
Posted 2006-02-20 10:38 AM (#37538 - in reply to #37528)
50025
Reg, I think you are talking about the Dexter Nevr-Lube axles, which have been available for several years.  They don't seem to be catching on, and I can understand why.  They are expensive, and the bearing capsules are replaced as a unit.  If you have a problem on the road, the chances of finding a replacement are very slim, and the  hub won't accept normal bearings and races, etc.
Most of the heavier axles are oil bath, from 8000# on up.  However, we frequently pack oil bath axles in grease for our customers.  For local use, it pretty much eliminates the leak problem and the task of checking the oil level frequently.  Oil bath axles do run cooler on long road trips, however.
Congress
Posted 2006-02-20 10:50 AM (#37540 - in reply to #37528)
I really like oil bath hubs for a trailer that is used quit often. Generally the only difference in the hubs is the fact that the oil bath requires a hub with threads so a threaded oil cap can be screwed into it. This is only with the 8,000 pound and lower axles though, all the 9,000 pound and up have the threaded cap in them. We changed the 10,000# dexter hubs on our car trailer from grease lubrication to oil, only thing we had to do was clean all the grease from the hub, spindle, and bearings then use 90 weight gear oil in them.
Only draw back with oil lube I have seen is when a trailer sits over time, the top of the spindle and bearings are not lubricated unless you spin the wheels every so often. Grease is always on the internal parts.
I have no experience with the never lube type hubs mentioned, they do seem like they would be really nice. Do they have grease or oil in them?
Reg
Posted 2006-02-20 3:49 PM (#37555 - in reply to #37528)
2000500100252525
Maybe if I was doing longer trips, but they'd have to be MUCH longer and a lot more of them for any benefit. The last one was only about 6,750 miles and the one before that was only about 5,200 - other than that most of them are under 1,000 in fact many are 100 or so. The trailers that most of us here are running aren't in the size range where oil bath hubs are the norm and we're not doing the sort of mileage that would justify the investment.
For some odd reason I tend toward Molybdenum-disulphide greases whenever I can find them - maybe the ads got to me (-:
For my boat trailers it would be even less interesting, VERY short trips, MUCH lighter duty axles, MUCH more exposure of the outer cap to submerged hazards at launch/retrieve time. I feel that among other things grease is a pretty good sealant against the entry of water when the axles are totally submerged.
Broken Bit
Posted 2006-02-21 10:32 AM (#37616 - in reply to #37528)
Howdy All,
Just a quick note on oil bath vs. grease-- I have oil bath hubs on one of our goosenecks.  They are 8,000# Dexter axles.  Trucking livestock for a living I was looking for heavy duty, low maintenance, and ease of use-- The oil bath hubs only provided the heavy duty part.  They are a pain and not only cost more money to start with, but more money to maintain, especially if a leaking seal is not cought right away and has time to soak your brake shoes with gear lube.  They are heavy duty, but unless you have a heated shop and alot of time on your hands, I'd stick with grease hubs for 98% of folks out there.  P.S.  I just ordered a new trailer, and it does NOT have oil bath hubs,  And keep in mind which horse you tie anywhere near those wheels, those plastic caps can get "pawed" off real quick!  Oh yeah, one more thing, never reuse your old wheel seal, so any time you want to get into your brakes to have a look, or fix something... you can count on at LEAST a $20 seal.
