trailer brakes pulling hard to one side
Last activity 2006-02-06 6:28 PM
4 replies, 3985 views
cracly
Reg. Aug 2005
Posted 2006-02-06 11:50 AM (#36619)
Subject: trailer brakes pulling hard to one side
When I pulled my trailer the other day I had to brake hard as I came upon an accident. The trailer pulled hard to the right... scary and not normal... what is causing this? Anyone have an idea of where to start. The truck is an 01 F250 diesel, trailer is an 03 Circle J Riata GN? Is this a truck or trailer problem. I'd like to have an idea of what I am dealing with before I haul it to the repair shop! Thanks for your imput
Catherine
xyzer
Reg. Apr 2004
Posted 2006-02-06 12:12 PM (#36620 - in reply to #36619)
Subject: RE: trailer brakes pulling hard to one side
Originally written by cracly on 2006-02-06 9:50 AM
When I pulled my trailer the other day I had to brake hard as I came upon an accident. The trailer pulled hard to the right... scary and not normal... what is causing this? Anyone have an idea of where to start. The truck is an 01 F250 diesel, trailer is an 03 Circle J Riata GN? Is this a truck or trailer problem. I'd like to have an idea of what I am dealing with before I haul it to the repair shop! Thanks for your imput Catherine
Catherine....I would try a panic stop with the truck only.....That would eliminate or confirm the truck. Look over the inside of your wheels on the truck for any fluid leakage it would probably be the left side to cause it to pull to the right. If it stops with no pull then it is a trailer issue. It could have a bad connection to one side or the other of the axles or they need adjusting. I am betting it is the truck but that is just a guess. Let us know how the truck alone stops.
Edited by xyzer 2006-02-06 12:14 PM
cracly
Reg. Aug 2005
Posted 2006-02-06 12:36 PM (#36622 - in reply to #36619)
thanks... I'll check on the way to work and let you know!
huntseat
Posted 2006-02-06 3:36 PM (#36639 - in reply to #36619)
1000500100100100100252525
Tire inflation is the first thing that comes to mind...
iCE CRM
Posted 2006-02-06 6:28 PM (#36645 - in reply to #36639)
My bet is aloose connection on the left side possibly ground
