Material for slide-in slats on stock trailer?
Last activity 2006-01-31 2:54 PM
15 replies, 18540 views
Sharon
Posted 2006-01-30 9:18 AM (#36205)
Subject: Material for slide-in slats on stock trailer?
I want to put slide-in clear slats in the gaps on the sides of my 1997 Bonanza steel stock trailer.  The shop wants $300 for materials and labor (there aren't any rails yet for the slats to slide into).    I guess that's not a bad price but frankly I don't have that kind of money.
What material do I want to use for the slats, and where can I buy it?  Do they have anything at Home Depot that would work?  The shop said they'd use "a corrugated poly material" that they say is stronger than plexiglass... but I have to wonder how clear it is.
Thanks,
-Sharon
barry
Posted 2006-01-30 9:36 AM (#36208 - in reply to #36205)
Subject: RE: Material for slide-in slats on stock trailer?
My CM trailer just has darkend plexiglass for the butt side slat openings.  They do have some nice aluminium tracks that hold the plexiglass. Don't know where you can buy that - CM sells it.  It is just riveted to the trailer wall.  Makes it nice and easy to slide the "glass" in and out depending on weather.
Dawnya
Posted 2006-01-30 9:46 AM (#36210 - in reply to #36205)
1001001001002525
The brand name is Lexan = colored plexiglass.
Call your local glass shop, they usually carry it.
Mine has rails that it slides in, BUT, hubby just drilled holes in the uprights and uses a good rubber washer to attach (inside trailer)
If there's a will, there's a way!
terri s
Posted 2006-01-30 11:06 AM (#36215 - in reply to #36205)
500100100100
Dawnya is right and there are a number of places on the internet that sell it; just need to look under window type websites rather than horse trailer type sites. If they think they have a captive market, you will pay through the nose. Don't forget your local lumber yard, we have gotten a number of things through them that we wouldn't have thought of at first.
Sharon
Posted 2006-01-30 11:54 AM (#36218 - in reply to #36205)
OK, Home Depot carries clear Lexan in 3x6' sheets for $75 each.  Is that a decent price?  It's roughly the same price as the trailer shop wanted to charge for their corrugated stuff.
farmbabe
Posted 2006-01-30 1:32 PM (#36224 - in reply to #36205)
1000500100100
The only way know if the price is right is to shop around. Ask local harware stores- I found they can be less then HD.
I also had plexiglass in a different trailer I had once. I didn't like it. It was the only air flow source and it was a pain to take out and in. I didn't haul in the winter, like I tend to do now. But if you need it,  you need it.
efaubert1
Posted 2006-01-30 2:35 PM (#36231 - in reply to #36205)
50010025
Good price? Depends on whether you can find it cheaper. Extrusion grade polycarbonate ( GE tradename is Lexan) runs about $2.13 a pound, and then you add in the production, shipping and retailers profit.  Anyway, plexiglass is acrylic just for the record, and will be cheaper than Lexan, which is what bullet proof glass is made from. Try this link, they have 33" x 19" x 1/8" thick plexiglass for like $35 bucks and you might not have to cut it. Cutting it is the hardest part, as if done incorrectly it will fissure crack. If you try the last link just put plexiglass into the search function for "word" and it will pop up a page where you can have custom sheets made and still be cheaper than local big box store and you wont have to cut it.
http://stores.ebay.com/eStreetPlastics
http://search.ebay.com/plexiglass_W0QQfromZR40
http://www.professionalplastics.com/cgi-bin/main/co_disp/displ/pgrfnbr/3/sesent/00
TRAILERMAN1957
Posted 2006-01-30 5:35 PM (#36250 - in reply to #36205)
GO TO YOUR LOCAL GLASS DEALER AND THEY WILL CUT IT TO THE SIZES YOU NEED YOU MIGHT HAVE TO MEASURE IT YOUR SELF BUT MOST COMPANIES WILL DO IT FOR YOU.THEN YOU CAN PRE DRILL THE HOLE IN THE PLEXIGLASS ONE SIZE LARGER THAN THE RUBBER WASHER SELF DRILLER SCREW YOUR USING AND YOU SHOULD'NT HAVE ANY PROBLEMS WITH IT. JUST REMEMBER DONT OVER TIGHTEN THE SELF DRILLIN SCREW.
GOOD LUCK
Sharon
Posted 2006-01-30 5:52 PM (#36252 - in reply to #36205)
OK I'm a bit lost with this whole screw / rubber washer thing. I thought the shop would just weld rails on that the slats could slide into? Is there some reason not to do that?
iCE CRM
Posted 2006-01-30 5:56 PM (#36253 - in reply to #36250)
I have a buddy in the sign business and they keep it in stock dark and clear. If you have one of these close they may have it in better sizes. Most hdwe stores don't have it in as long of lengths.
Dawnya
Posted 2006-01-30 9:41 PM (#36266 - in reply to #36252)
1001001001002525
Originally written by Sharon on 2006-01-30 5:52 PM
That would be ideal, but more expensive.
The 'screw/rubber washer thing' is just another option.
barry
Posted 2006-01-31 7:20 AM (#36279 - in reply to #36205)
I sure like the alum track. It makes it so easy to slide in/out depending on the weather. Here is KC we can have 70 degrees one day and 20 the next as we change seasons. It's nice to be able to do that on medium temp days when I don't want wind blowing through the drop downs directly on the horses' faces and when leaving the plexiglass in would cause the trailer to get too warm.
qhgirl
Posted 2006-01-31 8:20 AM (#36281 - in reply to #36205)
This might be a stupid question.. but could you use some type of heavy material to block the wind?
I have plexiglass in my trailer right now, it raddles some (like any stock trailer) but I had a thought, I wonder if I had heavy duty snaps put in on the inside of the trailer, if I could use heavy waited canvas (sort of like those heavy duck turnout rugs for horses) would that work?  It would be VERY quick and easy to install and easy to store.
terri s
Posted 2006-01-31 8:29 AM (#36282 - in reply to #36205)
500100100100
When I had the trailer that required plexiglass, mine was two pieces along the backside, one long one in front of the horses. This way, I could take out only half to increase ventilation but still leave protection and use it partially enclosed. Still think plexiglass is a PITB. but that did give me some flexibility in adjusting to the weather.
TRAILERMAN1957
Posted 2006-01-31 10:33 AM (#36293 - in reply to #36252)
WELDING ON A STEEL TRAILER WILL BURN THE PAINT AND IT COSTS ALOT LESS IF YOU DONT HAVE TO PUT THE TRACK ON THE TRAILER
efaubert1
Posted 2006-01-31 2:54 PM (#36315 - in reply to #36205)
50010025
You can rivet the track on also, you don't have to weld it. 1/8" plexiglass isn't that heavy.
