04 FORD F150 HARD TO KEEP TRAILER OFF BED
Last activity 2006-01-27 2:41 PM
2 replies, 3521 views
JWALDEN
Posted 2006-01-26 8:51 PM (#36047)
Subject: 04 FORD F150 HARD TO KEEP TRAILER OFF BED
I HAVE A 04 FORD F-150 AND IT IS HARD TO KEEP THE TRAILER FROM HITTING BED ANY SUGGESTIONS? THANKS
Reg
Posted 2006-01-26 9:08 PM (#36051 - in reply to #36047)
Subject: RE: 04 FORD F150 HARD TO KEEP TRAILER OFF BED
2000500100252525
You didn't give much info.
Is this a gooseneck trailer ?
Where is it hitting ?
If the trailer is hitting the sides of the box, extend the coupler tube.
An inch or so won't make much difference to the trialer's geometry, check tire temperatures after say 10 miles of highway driving to see if you have tilted the trailer so far back that the rear tires are carrying more load than the front ones. If there is a perceptible difference in temperature between the trailer's front and rear tires you've probably tilted it back too far. Start out with properly inflated tires, of course, check them when COLD, e.g. not driven more than a mile in the preceeding 3 hours.
If this doesn't answer you question, please supply more detail.
gabz
Posted 2006-01-27 2:41 PM (#36080 - in reply to #36047)
1000100100100252525
http://www.horsetrailerworld.com/forum/thread-view.asp?threadid=3134&start=1
