Poll TRAILER NECK NOT TALL ENOUGH FOR TRUCK BED
Last activity 2006-01-29 10:17 PM
10 replies, 5033 views
JWALDEN
Posted 2006-01-26 8:05 PM (#36043)
Subject: TRAILER NECK NOT TALL ENOUGH FOR TRUCK BED
I HAVE A 2004 F-150 AND I HAVE TO WATCH THE TRAILER LIKE A HAWK SO IT DON'T HIT THE TRUCK BED. ANY SUGGESTIONS?
Posted 2006-01-26 10:28 PM (#36057 - in reply to #36043)
Subject: RE: TRAILER NECK NOT TALL ENOUGH FOR TRUCK BED
Adjust the hitch.
Most Goosenecks hitches can be adjusted up & down. On my F350 I had to raise my hitch one hole (about 2") higher to clear my bed rails (I've got a roll up bed cover and the rails stick up another inch higher than the stock truck sides).  You don't want to go too high or all the weight  ends up on the rear axle and you drag your trailer bumper when you cross streams or dips.
If you have to raise the gooseneck hitch so high to clear the bed that it puts the trailer on an angle, you may need to put a lift on the axles and raise the overall trailer height. I see this frequently any way. As folks try to increase the ground clearance for back country or forest service roads.  It's another 2" or so of step up for the horse, but at the same time adds two inches of ground clearance at the rear bumper, so you don't drag. It's not something you see a lot at the fairground or rodeo grounds, But ranchers, outfitters and endurance riders do it a lot.
Edited by Painted Horse 2006-01-26 10:32 PM
walkin
Posted 2006-01-27 5:14 AM (#36058 - in reply to #36043)
500100
Take the bed off and put a flat bed on the truck.
Reg
Posted 2006-01-27 6:32 AM (#36059 - in reply to #36058)
2000500100252525
Originally written by walkin on 2006-01-27 6:14 AM
Abso_friggin_lutely (-:
Make that sissy street truck a fer real Fahm truck, build some wood stake sides and tailgate for when you need to haul hay.
See Hillsboro about an aluminum flat with trap door and hitch ball all built in.
\R
PS
MIfarmbabe
Posted 2006-01-27 7:35 AM (#36062 - in reply to #36043)
5002525
And don't forget the chrome exhaust pipes on the roof...................
huntseat
Posted 2006-01-27 1:37 PM (#36076 - in reply to #36043)
1000500100100100100252525
Over cab lights...a personal fave!
Reg
Posted 2006-01-27 3:14 PM (#36081 - in reply to #36062)
2000500100252525
Originally written by MIfarmbabe on 2006-01-27 8:35 AM
Them uns is air horns.
STACKS, no baffles - VERTICAL !
Rander
Reg. Mar 2005
Posted 2006-01-27 11:12 PM (#36103 - in reply to #36043)
And a gun rack in the back window.
Dawnya
Posted 2006-01-27 11:28 PM (#36104 - in reply to #36043)
1001001001002525
and a couple whip antennas.
Back to your question...we had the same problem with an older 4h hooked to a '04 Dodge.  The drop wall is too short.  We could raise the neck/coupler but all that did was raise the front of the trailer - not off the bed.
Had to get a new trailer - hated that.
Reg
Posted 2006-01-27 11:40 PM (#36106 - in reply to #36103)
2000500100252525
Originally written by Rander on 2006-01-27 12:12 AM
Bows are so much quieter - you never know when you might hit the wrong sort of animal and have to sneak away quietly. Loud bangs are a dead(pun) giveaway.
PS Don't shoot at the big ones that have saddles and/or people on them.
Owners get SO ticked off, even if you miss.
paintthatain't
Posted 2006-01-29 10:17 PM (#36188 - in reply to #36043)
I have a lifted '03 chev 2500hd diesel and bought a '93 sooner GN. We had major clearance problems. The trailer has dexter tortional axles so I cut the entire axle assembly loose and welded in 3 1/2" box tubing between the axle & frame. Was a pretty simple fix and have talked to many dealers that will do it for you.
Good Luck, CS
