towing capacity
Last activity 2006-01-29 8:24 PM
9 replies, 5185 views
herrins
Posted 2006-01-25 7:29 AM (#35961)
Subject: towing capacity
I have a 1995 F250 3/4 ton with a straight-six. The only weight ratings I can find are in the door jamb. The GVWR is 6,600. Can anyone tell me how much weight I can SAFELY tow? I would like to get a 12' bumper-pull stock trailer and the range of weights is between 1,600 and around 3,500. I would be hauling two horses locally. Should I worry about getting a trailer that is too light, such as the 1,600 pound one? Thanks,
Sheri
terri s
Posted 2006-01-25 8:38 AM (#35962 - in reply to #35961)
Subject: RE: towing capacity
500100100100
Your owners manual should have a section on towing. It would at least give you an idea, based on your truck weight, of about what you can tow.
herrins
Posted 2006-01-25 3:14 PM (#35972 - in reply to #35961)
I forgot to mention that I could not find the owner's manual...I also have not been able to find where to purchase one. I contacted Ford and they're supposed to get back with me, but I haven't heard from them.
Sheri
efaubert1
Posted 2006-01-25 3:59 PM (#35976 - in reply to #35961)
50010025
 Try these links for starters, it just takes a minute to search the net.
http://cgi.ebay.com/ebaymotors/1995-Ford-F-Series-Owners-Manual-w-case-95_W0QQitemZ8032397524QQcategoryZ34221QQrdZ1QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/1995-FORD-F-SERIES-4x4-OWNERS-MANUAL-COMPLETE-MINT_W0QQitemZ8032670096QQcategoryZ34221QQrdZ1QQcmdZViewItem
nathaniel
Posted 2006-01-25 8:37 PM (#35985 - in reply to #35961)
Originally written by herrins on 2006-01-25 8:29 AM
is your truck an auto or manual either or your truck can pull it its got an 300 inline six right
Sheri
herrins
Posted 2006-01-26 4:27 AM (#35999 - in reply to #35961)
My truck is an automatic...
gabz
Posted 2006-01-27 4:05 PM (#36087 - in reply to #35961)
1000100100100252525
http://www.ford-trucks.com/specs/index.html
Go to this site and look up your truck. It will tell you the maximum tow values.
Be sure to check the hitch on the back of your truck too to see if it is capable for weights over 5000 ... sometimes not.
With a GVWR of 6600... you aren't going to have a large weight allowance for towing.
flintspr
Posted 2006-01-29 12:50 PM (#36166 - in reply to #35961)
Your drive train and suspension will easily handle this load.  If you don't want to go real fast, your straight 6 (I'm assuming a 300) will do this job, just don't try to run it too fast and overheat.  I pulled a two horse stidham and 2 horses with a Ford 150 and 300-6 in Montana at about 5000 feet.
xyzer
Reg. Apr 2004
Posted 2006-01-29 1:31 PM (#36167 - in reply to #36166)
Originally written by flintspr on 2006-01-29 10:50 AM
I agree with flintspr...plenty of chassis to handle a fair tow. IMHO your weakest link is the tranny....make sure it has a cooler! The Ford 300six is one good ol motor!
herrins
Posted 2006-01-29 8:24 PM (#36182 - in reply to #35961)
Thanks everyone. It was difficult to even get an idea of how much weight I could safely tow due to the truck's make up (the motor is great!). Now I'm fairly comfortable with buying the stock trailer I really wanted that weighs 3,000 pounds empty.
sheri
