Refridgerator problem
Last activity 2005-12-30 10:40 PM
4 replies, 3794 views
Steve
Posted 2005-12-28 5:03 PM (#34465)
Subject: Refridgerator problem
I have a LQ trlr with a Norcold refridgerator , gas/electric and the LP mode works normal , but the electric now has to be turned way up to cool it . Last summer while camping and plugged in there was a thunderstorm and the current blinked several times,and then went out. I had forgot we were on the electric mode of the fridge, could this be the cause of the problem and what might be wrong ? Thanks
mgisse
Reg. Dec 2005
Posted 2005-12-28 5:11 PM (#34466 - in reply to #34465)
Subject: RE: Refridgerator problem
it sounds like the board . there is a problem with the board and the thermister (thermostat) working together . any high or low voltage can damage the board . mostrv dealerships can test the board and tell you where the problem is at
hav2ride
Posted 2005-12-29 8:57 AM (#34490 - in reply to #34465)
1000500100100
Could the places where you are camping have 20amps instead of 30?  This could be a problem if you are running other things at the same time your fridge is set for electric power.  Sometimes you can even have 30 and yet not be able to draw enough power if there are too many trailers plugged into the same source.  Mnay times when I camp at shows, I will leave the fridge on the ac/lp mode so the fridge can pick the best power source.
Roger
Reg. Feb 2005
Posted 2005-12-30 1:07 PM (#34562 - in reply to #34465)
 From my experience I would thinks its the 110 volt Heating Element. Most of the time when you have board problems it wont work at all on electric. Sometimes a heating element wont go completely out it will just start pulling more amps which will cause breakers to kick or a fuse to blow on the board. Other times it just wont get hot enough. Its similar to one on a household water heater. It would be a cheaper place to start, Most heating elements run about $30.00 and circuit boards run about $150.00.
Steve
Posted 2005-12-30 10:40 PM (#34599 - in reply to #34562)
Thanks for the reply. Is the element or the board something I could check , or take off and bring in or would I be as well to take the trlr to an rv dealer ? I do seem to remember it kicked a breaker afterwards while plugged in at home. Thanks again
