trailer /truck wiring
Last activity 2005-12-09 6:37 PM
6 replies, 4698 views
mustangs
Reg. Dec 2005
Posted 2005-12-06 2:34 PM (#33797)
Subject: trailer /truck wiring
i have a 2003 dodge, just got a Logan Stockman trailer, it and the truck have the 7way plug in, my problem is the lights in the trailer and the tack room won't work, what do i need to get this problem fixed????????
mgisse
Reg. Dec 2005
Posted 2005-12-06 4:43 PM (#33804 - in reply to #33797)
Subject: RE: trailer /truck wiring
it sounds like a fuse that is blown . under the hood is a fuse box . one of the yellow fuses (20 amp )is probly blown.
Kay
Posted 2005-12-07 8:38 AM (#33822 - in reply to #33797)
50025
Check to be sure you have a "hot" wire hooked into your truck plug, and that the fuse is in the line.  Most interior lights are wired separately to the "hot" or "accessory" post, and will work as long as the trailer is plugged into the truck.
efaubert1
Posted 2005-12-09 8:22 AM (#33892 - in reply to #33797)
50010025
You need to visit this site. It will help you put it all together. Nice pictures and details.
http://www.marksrv.com/wiring.htm
ridin4alivin
Reg. Oct 2005
Posted 2005-12-09 10:57 AM (#33900 - in reply to #33797)
Some wiring configurations require the trucks running lights or ignition to be on for the tack room/interior lights to work.
Reg
Posted 2005-12-09 6:31 PM (#33908 - in reply to #33900)
2000500100252525
Originally written by ridin4alivin on 2005-12-09 10:57 AM
Right.
Recent Fords DO.
recent Chevv/GM do NOT.
Dodges - - I don't know - - RTOM - read the owners manual.
xyzer
Reg. Apr 2004
Posted 2005-12-09 6:37 PM (#33910 - in reply to #33797)
"99" Dodge always on... "03" Dodge the same.....check for power at bumper receptical...if none check fuse... If you do have power at bumper Check plug and see if it wired correctly then you can work back from there.
CAV CIRCUITFUNCTION
1 Z13 12BKGROUND
2 B40 12LBTRAILER ELECTRIC BRAKE OUTPUT
3 L76 12BK/ORTAIL LIGHT (Trailer Tow Relay in PDC)
4 A6 12RD/TN*FUSED B(+)   (40A, Always Hot, F8 in PDC)
5 L63 16DG/RDLEFT REAR TURN SIGNAL
TRAILER TOW
6 L62 16BR/PKRIGHT REAR TURN SIGNAL
CONNECTOR
7 L1 16VT/BKBACK-UP LAMP
FIGURE 1:   7-Terminal Trailer Tow Connector
* some trucks have orange or red/orange wires for B+
Edited by xyzer 2005-12-09 6:47 PM
