How Much? Fixing Up Trailer
Last activity 2005-11-07 3:26 PM
2 replies, 3742 views
Steph_735
Reg. Dec 2003
Posted 2005-11-06 7:54 PM (#32754)
Subject: How Much? Fixing Up Trailer
I want to paint my trailer, replace the running boards, add roof vents and tie rings and replace 1 cracked wood plank. And i want to line the walls with either plywood or rubber. I'm also replacing the jack as its bent also.
But how much do you think it would cost for paint to paint a 16ft trailer inside and out? My uncle would be doing the work and he restores old cars and also does some other work and is really good and is only charging me for the supplys.
Reg
Posted 2005-11-07 10:42 AM (#32777 - in reply to #32754)
Subject: RE: How Much? Fixing Up Trailer
2000500100252525
Your uncle can probably guess this up better than I can, but as a first guess I'd say 2 gallons of primer, a gallon of thinner and 2 gallons of paint. There again, it will depend on the process, may be able to paint over existing enamel, may or may not need a "hiding" coat, etc.
A 16ft trailer has a LOT more surface area than a car.
Price plywood by the sheet, around here regular lumber yards are a better deal than big outlets.
You could say "bye" to a thousand (or two).
Roger
Reg. Feb 2005
Posted 2005-11-07 3:26 PM (#32786 - in reply to #32754)
  If the trailer is an old steel trailer you may be better off trading it. Unless your uncle is giving you a good deal on labor sometimes you can invest more in one than you can get back out .
