sweating of supports
Last activity 2005-10-04 3:54 PM
3 replies, 4097 views
morgans2
Reg. Mar 2005
Posted 2005-10-03 9:15 AM (#31249)
Subject: sweating of supports
Hi,
My dressing room has foam insulation between the supports.  The supports themselves are not insulated. I went camping with a friend this weekend and I was awakened by a drop of water that had condensed above my head in the GN area.  Any suggestion on what to place on the ribs?  I'm not looking to completely finish my dressing room.
Morgans2
tnmulerider
Posted 2005-10-03 4:04 PM (#31277 - in reply to #31249)
Subject: RE: sweating of supports
I have had the same problem.  A friend told me that he had drilled 3 holes in each support (one in the center and one on each end) and used the foam insulation that comes in a can.  It worked pretty well but can be messy.  If you try doing this, you need to put the insulation in the center hole and watch for it to come out the holes on each side.  The problem I encounter was that when it start coming out of the holes on the sides, you have already put to much insulation because as the insulation expands it keeps coming out the side holes.  I don't know now to gauge the right amount.  Maybe someone can give you a better suggestion.
Terri
Posted 2005-10-04 10:57 AM (#31309 - in reply to #31277)
200050010010010025
If you do use the foam, get the minimal expanding stuff.
martyg
Posted 2005-10-04 3:54 PM (#31319 - in reply to #31309)
You will need to cover the aluminum with some type of wall covering..there are a lot of posts here on the site re this subject. The bottom line is that if you camp in cold weather with the high humidity inside a trailer, these steel or aluminum supports are going to have condensation on them. Simply covering them with wood paneling is sometimes not enough, in winter the paneling will actually have moisture condense on it. When I finished my trailer I cut foam betwen the aluminum supports and then attached furring strips to the supports and then put another layer of foam between the furring strips. The 3/4 wood strips have enough insulation that they keep any moisture from condensing on the paneling or whatever you attache for wall covering. Even if you attach paneling to the walls or ceiling with screws into the steel or aluminum supports, the screw heads can actually condense and drip on your head.
