how to mount privacy curtain on interior LQ door
Last activity 2005-09-21 2:57 PM
12 replies, 7429 views
rollingrfarm
Reg. Jun 2005
Posted 2005-09-17 2:59 PM (#30528)
Subject: how to mount privacy curtain on interior LQ door
Has anyone come up with a way to mount a curtain rod or place a curtain on the interior of the LQ door without drilling holes in the door itself to mount a curtain rod?  If not, don't be looking in my door window if you  don't want to see an overweight middle-aged woman changing clothes.  I just hate to drill holes anywhere in my trailer!  And gray taping a curtain up over the door window just kinda ruins the ambience of all that money I spent on the interior!
KR
RbarL
Posted 2005-09-17 3:57 PM (#30530 - in reply to #30528)
Subject: RE: how to mount privacy curtain on interior LQ door
KR - Is there a recessed window in your door? If so, you could maybe find a springloaded rod for it. I think I saw some really short ones at WalMart once.
Ours has a shade mounted over it. It came like that from the LQ Co. It doesn't look decorative, kinda plain, but it matches all the other shades.
Edited by RbarL 2005-09-17 3:59 PM
Posted 2005-09-17 6:42 PM (#30537 - in reply to #30528)
Drilling holes in the inner skin of the door isn't such a bad thing.  The key is the inner skin.  Use a small drill, like a 1/16 th drill or smaller, then use the proper sized drill for the screw.  But if you still don't want to drill the holes, I would suggest glueing the hangers with "crazy glue"  or get a windshield / rear view mirror glue kit.
Terri
Posted 2005-09-17 7:34 PM (#30538 - in reply to #30528)
200050010010010025
You could try magnets.  I made a screen for my trailer door and used magnets to keep it in place.
johnnyr1965
Reg. Jun 2005
Posted 2005-09-17 7:43 PM (#30539 - in reply to #30528)
Use very dark window tint.
Turfa
Posted 2005-09-18 9:11 AM (#30549 - in reply to #30528)
My door is Aluminum, so I will be placing a steel bar above the window with double sided foam tape.  I will then use magnets to hold up the curtain.
rollingrfarm
Reg. Jun 2005
Posted 2005-09-18 9:46 AM (#30551 - in reply to #30528)
Thanks folks, you sure are creative!
KR
CrazyAgain
Reg. Jun 2004
Posted 2005-09-18 12:56 PM (#30557 - in reply to #30528)
I have a window in my LQ door that needed a flat privacy curtain and my Mom and I actually designed a shade made of white denim type fabric - doubled and seemed.  We used a velco strip to attach it to the top of the window and another strip on the bottom.  We included fabric ties (2), so this shade can be rolled up and held up for when we want the window open.  Works just perfect!
I have a roll out screen door that doesn't leave room between door and screen for a regular shade or any frame that would support a shade or curtain.
Edited by CrazyAgain 2005-09-18 1:03 PM
RbarL
Posted 2005-09-18 1:42 PM (#30558 - in reply to #30528)
Great ideas. I should have thought of the velcro one myself. I made curtains for all the windows in the back of our trailer. Cowboy shower. I just stuck a velcro on the corners of the material and on the aluminium walls. Voila! No hardware to worry with. No peep shows. Life is good!
gemm
Reg. Feb 2005
Posted 2005-09-18 3:48 PM (#30568 - in reply to #30528)
100100100100252525
Yep, I'm one of the velcro crowd too. Works great and the curtain sticks right next to the wall, so no lookie-loos can peep in the sides either.
pegasus
Reg. Mar 2005
Posted 2005-09-18 9:37 PM (#30586 - in reply to #30528)
I, too, did not want to treat anyone to a strip show so I used a tension rod from Wally World to mount just above the door. It would have fit in the actual door opening but also worked on the wall to one side and the microwave cupboard on the other side. I also took the door off the bathroom because it opened into and took up too much LQ space. I mounted a regular cafe curtain rod inside the bathroom over the door opening to hang a curtain. Drilled small pilot holes into the molding trim and screwed the hardware into that for stability. Was going to sew curtains for both spaces but I found a denim tab top window panel 84" long that solved both door and window curtain problems. I cut the tab top off the panel to make it the right length for the bathroom door and hung it with curtain clips. Then I sewed the tab top to some red vintage cowgirl fabric for the door privacy panel. It all looks custom made and color coordinated with very little sewing. The outside door panel ties back with a bandana when not in use and the bathroom curtain slides back out of sight. I made sure the rod extended past the door opening on both sides so the curtain could go either side, out of the way. Good luck with yours!
jakey1
Reg. Dec 2003
Posted 2005-09-19 10:00 AM (#30605 - in reply to #30528)
I am also a Velcro fan.  I made a roman shade out of a pretty tapestry fabric and used 2" adhesive backed velcro above the window.
terri s
Posted 2005-09-21 2:57 PM (#30749 - in reply to #30528)
500100100100
Another option-use two of those large plastic hooks that attach to surfaces by suction. Put your curtain on a dowel rod and set each end of the dowel rod in a suction hook. No glue, no drilling. And if you don't want to sew, get towels of the right size and buy pinch clips; they will grab the towel fabric and you just slide them on the dowel rods like shower curtains.
Edited by terri s 2005-09-21 2:59 PM
