What really concerned me is that the gooseneck hitch on the trailer bent and the welds and supports broke immediately. It would have pulled free pretty easily! The reason for my posting is that, after that, I started to pay close attention to how trailers are reinforced at the hitch.');"> Featherlite (probably others too) have huge 1/4" plate steel gussets down to the hitch head. My 1997 Trailet 3 horse slant doesn't have anything nearly as substantial!');"> Should I be worried? ');"> Should I go to a weld shop and have reinforcements installed? I shudder to think what could have happened if the accident with my Kingston was on the road, and if there were horses on board. ');">');"> I want that trailer to hang on much better than it displayed it would! The Featherlite I inspected looked as if it could take a SUBSTANTIAL hit before it bent or pulled away. The weld shop that fixed my Kingston put a LOT more steel up there and said it would be much stronger than the original.');"> Any info will be appreciated. ');">"/>
Gooseneck Trailer Hitchhead Reinforcement
Last activity 2005-08-31 8:01 AM
8 replies, 7268 views
evallone
Reg. Jul 2004
Posted 2005-08-28 7:38 AM (#29675)
Subject: Gooseneck Trailer Hitchhead Reinforcement
I recently had a relatively minor accident with my 1985 Kingston two horse gooseneck. The front axle caught on a drain pipe, and was pulled off the trailer, in my driveway.1 What really concerned me is that the gooseneck hitch on the trailer bent and the welds and supports broke immediately. It would have pulled free pretty easily! The reason for my posting is that, after that, I started to pay close attention to how trailers are reinforced at the hitch.42 Featherlite (probably others too) have huge 1/4" plate steel gussets down to the hitch head. My 1997 Trailet 3 horse slant doesn't have anything nearly as substantial! Should I be worried? 37 Should I go to a weld shop and have reinforcements installed? I shudder to think what could have happened if the accident with my Kingston was on the road, and if there were horses on board. 57 I want that trailer to hang on much better than it displayed it would! The Featherlite I inspected looked as if it could take a SUBSTANTIAL hit before it bent or pulled away. The weld shop that fixed my Kingston put a LOT more steel up there and said it would be much stronger than the original.53
Any info will be appreciated. 29
Edited by evallone 2005-08-28 7:51 AM
Reg
Posted 2005-08-28 2:01 PM (#29684 - in reply to #29675)
Subject: RE: Gooseneck Trailer Hitchhead Reinforcement
2000500100252525
I think any welder will (or SHOULD) tell you that a weld that fails is a BAD weld. It should ALWAYS be the parent metal that fails. I'd guesss your trailer had some bad welds from day one and the driveway incident merely precipitated their failure.
So, unless there is a design weakness in your trailer a PROPER repair should be all that is needed. Useless amounts of metal added to an adequate design could actually weaken the total structure. I'm thinking of stress raisers, heat shrinkage stress, things like that.
If you have an adequate repair - all done.
chadsalt
Posted 2005-08-28 3:05 PM (#29687 - in reply to #29675)
1000100100100100
if the repair was done by a good shop then i wouldnt worry about that trailer.  as for any of the others.........the coupler is rated to xxxxx pounds, ive always taken this rating as to a rolling load rating, of course i may be wrong.  i would be curious to know if the actual hitch components are rated to a static load such as hanging the trailer in the air. ive seen several winch ratings with 2 rateing on them, one for static loads like pulling a log and a rolling load such as winching a vehicle onto a trailer.
either way catching the axle hard enough to pull it off created a temporary static load of who knows how much weight....some thing has to give. i dont think i would worry about it.
Edited by chadsalt 2005-08-28 3:11 PM
evallone
Reg. Jul 2004
Posted 2005-08-28 8:49 PM (#29690 - in reply to #29684)
evallone
Reg. Jul 2004
Posted 2005-08-28 8:50 PM (#29691 - in reply to #29684)
 Thanks! I feel much better reading your feedback!
evallone
Reg. Jul 2004
Posted 2005-08-28 8:52 PM (#29692 - in reply to #29687)
 Many thanks! Help from knowledgeable people is so appreciated.
Kay
Posted 2005-08-29 12:37 PM (#29716 - in reply to #29675)
50025
The Featherlite was re-inforced with steel at stress points because the frame is aluminum.  The Trail-et has a steel frame.  Look at other aluminum framed trailers.  They all use steel gussets, some of them obvious and some of them sandwiched between two pieces of aluminum.  This is a GOOD thing (apologies to Martha).
Reg
Posted 2005-08-30 8:47 PM (#29810 - in reply to #29716)
2000500100252525
Originally written by Kay on 2005-08-29 12:37 PM
Gussets are needed, regardless of the material.
Given that the coupler tubes are ALL made of steel, there is a very limited choice of where the material transition can be made, i.e. they can't weld aluminum gusset plates to the steel coupler tube. MOST aluminum frame goosenecks have a small steel sub frame near the nose, not so much "for the strength of steel" as a simple and low cost way of transitioning from the aluminum frame to the steel coupler tube. Welding dissimilar metals is POSSIBLE, though I'm fairly sure that it isn't practical with steel and aluminum. Adhesives would be possible, probably very good, but would likely have market acceptance problems (-:
The gussets are there more to stiffen the coupler tube (minimize whip) than to add any needed "strength".
Edited by Reg 2005-08-30 10:27 PM
Mr. Trailer
Posted 2005-08-31 8:01 AM (#29817 - in reply to #29810)
Originally written by Reg on 2005-08-30 9:47 PM The gussets are there more to stiffen the coupler tube (minimize whip) than to add any needed "strength".
they (gussets) minimize whip (and the potential breaking of the tube or other related components) by adding strength to the tube reg....
