Dual Batteries and Test Panel Question
Last activity 2005-08-22 1:24 PM
1 replies, 4057 views
Hillview
Posted 2005-08-22 1:11 PM (#29479)
Subject: Dual Batteries and Test Panel Question
I have two marine batteries on my trailer. I also have a test panel that shows me the current fresh water, waste tank, and battery level. Does the test panel display battery level per battery or are they combined? If it depends on how the batteries were hooked up, is there an easy way to tell?
justinc
Reg. Jun 2005
Posted 2005-08-22 1:24 PM (#29480 - in reply to #29479)
Subject: RE: Dual Batteries and Test Panel Question
If you have two 12v batteries : Your test panel should be showing the level of both batteries.Your batteries will be connected with a jumper + to + and another  - to -.Your - terminal will be connected to the trailer frame.And you + should run into the trailer.
