Sundowner Ramp
Last activity 2005-08-26 8:03 PM
5 replies, 7986 views
wddawson
Reg. Aug 2005
Posted 2005-08-18 11:36 AM (#29344)
Subject: Sundowner Ramp
Has anyone ever installed a ramp on their Sundowner?  I really wished I had bought one when I got my trailer, but hind sight is 20-20..........  It looks like it would just replace the rubber bumper and install a latch.  Anyone have any idea as to the cost?  No dealer close by, I bought it a the Dixie Nationals this year fom Bob Lewis, excellant dealer in LA.  Thanks for any and all help.
Zane
Reg. Oct 2004
Posted 2005-08-18 2:23 PM (#29351 - in reply to #29344)
Subject: RE: Sundowner Ramp
Depends on the year of your trailer--square or round door jambs.  The rubber bumper is removed and holes are drilled through the ramp "L" channel and self-tapping bolts are used to go into existing holes from bumper.  Additional vertical holes are drilled through the "underside" of the "L" channel and self-tappers are used here also.  Then the tongue-holder is mounted on the right door.  This keeps the ramp from rubbing on the cam-locks and turning them black from the rubber matting.  In some instances, the protective cover at the bottom of the cam-lock must be removed--where the doors join when closed.   All in all, it's about a 2 1/2 to 3 hr. job when you know what you are doing.  We charge $950. for an installed ramp. Is your trailer 6'9" or 8' wide ???  Also--freight on one of these is terrible---so we always try to keep extras in stock--which we have delivered on ordered trailers.  One way to save lots of added cost !!!  Hope this helps--but I can't speak for other dealers and what they charge !!  We do install our ramps on lots of other brand name trailers.   Zane.
wddawson
Reg. Aug 2005
Posted 2005-08-18 5:23 PM (#29359 - in reply to #29344)
Thanks Zane, my trailer is a standard (?) sundowner 727, I believe it's 6.5' wide, also its a 2003 model.
huntseat
Posted 2005-08-19 8:47 AM (#29383 - in reply to #29344)
1000500100100100100252525
I looked at Sunny's a few years ago and I wanna say the ramps were in the $800-1100 range.
Zane
Reg. Oct 2004
Posted 2005-08-20 12:03 PM (#29428 - in reply to #29344)
wddawson--if you check with Sundowner corporate at 800-765-3879, they can give you the number of your closest dealer.  Perhaps they can have a ramp shipped to their location on an ordered trailer for you--saves $$$$.  Good luck, Zane.
ISHOM
Posted 2005-08-26 8:03 PM (#29646 - in reply to #29344)
I bought a used ramp that had been damaged (spring/hinge assembly) for $300 and then took it to a local welder and had a hinge fabricated (without a spring).  Total cost $550.  Keep your eyes open and be creative.  I had the local sundowner dealer price one out for about $1000. including labor.  I found the used ramp in their "salvage" parts around back.  "luck".
