Ford transmission vibrates
Last activity 2005-10-07 7:56 PM
10 replies, 5361 views
BigT
Posted 2005-08-17 6:50 PM (#29318)
Subject: Ford transmission vibrates
I tried the diesel-stop and ford-truck forum and couldn't find what I am looking for. My Ford F-350 PSD started to vibrate when I go from 1 to 10 mph in first gear, after 10 mph I am still in first gear and the vibration goes away.  I would like to find a trouble shooting guide or a forum that I can find out what is  wrong.  It is a 4x4. The u-joints are tight, could it be the transmission, flywheel, torque converter, or something else. If anyone could steer me in the right direction I would appreciate it.
maccwall
Reg. May 2004
Posted 2005-08-18 12:43 PM (#29346 - in reply to #29318)
Subject: RE: Ford transmission vibrates
500
What year is the truck? I'm surpized the Diesel-Stop people couldn't help you. Most of those guys are pretty good.
Safe Riding,
Todd
Edited by maccwall 2005-08-18 12:45 PM
BigT
Posted 2005-08-18 12:53 PM (#29348 - in reply to #29318)
It's a 2002. I couldn't find an area in the forum for transmission problems.
maccwall
Reg. May 2004
Posted 2005-08-18 3:28 PM (#29354 - in reply to #29348)
500
If you go to the Diesl Stop and scroll down to the 1999-Up Super Duties section and then to the 7.3L Power Stroke Engine and Drivetrain forum, and ask the same question you asked here, somebody will give you an answer, I'm pretty sure of that, or you can do a search about your problem and most likely find an answer. If you can find a member by the name of Richter69, he's a wiz at trannies. Assuming your tranny is an automatic, it sounds like the torque converter. Does it do all the time or when just you are towing and how many miles are on the tranny? Has it ever been rebuilt? Any upgrades to it or is it stock? I can't remember if they put the dual mass flywheels in these trucks or not but if they did that could be a culprit also.
Safe Riding,
Todd
Edited by maccwall 2005-08-18 3:29 PM
MR176
Posted 2005-08-18 4:40 PM (#29357 - in reply to #29318)
It sounds like vibration of the carrier bearing in the middle of your 2 piece driveshaft. The bearing sits in a rubber isolator that can vibrate under heavy loads. The bearing can be shimmed to adjust the angle (I think there are different factory mounts for each wheelbase). The angle changes with compression of the rear springs so it may only vibrate under certain loading conditions. If this is indeed your problem, it's really not detrimental, just a little irritating.
Turfa
Posted 2005-08-18 6:11 PM (#29361 - in reply to #29318)
I bought a Ford once that had a simular problem.  The U Joints were tight but one of the caps was not seated right.  When the unit would start in a certain position the drive shaft would be off center causing a vibration.  Then it would get back on center and everytrhing would be OK.  Something to check.
Good Luck
Turfa
Posted 2005-08-18 10:46 PM (#29369 - in reply to #29318)
Try Flat Rate Tech.
http://flatratetech.com/cgi-bin/ubbcgi/ultimatebb.cgi
rockyrider
Reg. Jun 2004
Posted 2005-08-19 11:35 PM (#29421 - in reply to #29318)
100100100
Post your question here.
http://www.ford-trucks.com/forums/forumdisplay.php?f=69
Reg
Posted 2005-08-23 9:19 AM (#29518 - in reply to #29318)
2000500100252525
I'll betcha today's pay check that it is the bolts that (don't) secure the flex plate to the torque converter.
BTW, I don't get paid today.
BigT
Posted 2005-08-23 9:04 PM (#29545 - in reply to #29318)
I appreciate all the responses. I have been on the road for the last week and was unable to view this site. I will look in on all the sites and also try to find the problem with all the help I received on this forum.
BigT
Posted 2005-10-07 7:56 PM (#31427 - in reply to #29318)
I finally found out what was the cause of the vibration. The center carrier bearing was shot, and one u-joint was cracked.  At least I didn't break down on the road and it wasn't the transmission.
