DIY LIVING QUARTERS
Last activity 2005-08-25 8:05 AM
5 replies, 5174 views
D. REDDISH
Reg. Aug 2005
Posted 2005-08-17 3:14 PM (#29309)
Subject: DIY LIVING QUARTERS
I'M IN THE PLANNING STAGES OF PUTTING LIVING QUARTERS IN MY HORSE TRAILER. I HAVE SEVERAL QUESTIONS THAT I NEED HELP ON.
WILL 3" ROLLED BAT INSULATION WORK O.K. FOR MY LIVING QUARTERS?
WHAT GA. WIRE SHOULD I RUN FOR MY 12V SYSTEM? (SOLID OR STRANDED)
I PLAN ON USING OAK PANELING ON THE WALLS, WHAT IS BEST FOR CEILING?
I WILL HAVE A 42 GAL. FRESH WATER TANK IN MY BOOT BOX. DO I NEED TO USE A DRAIN VALVE AT THE WATER TANK FOR FREEZING WEATHER?
WHERE CAN I PURCHASE THE 12VOLT FUSE PANEL AND SWITCHES?
LASTLY, WHERE CAN I PURCHASE A PASS THRU DOOR FROM THE LQ TO THE FIRST STALL?
ANY HELP WILL BE GREATLY APPRECIATED.
DAVID
maccwall
Reg. May 2004
Posted 2005-08-17 3:59 PM (#29311 - in reply to #29309)
Subject: RE: DIY LIVING QUARTERS
500
It should be fine but remember if you compress insulation it loses it's R proporties. I would suggest the foam type or bubble wrap type as it's easiest to work with IMO.
I used 14 gauge stranded thru-out my trailer. If I had to do it again (a 3rd time) I'd use 12 but 14 is the norm from what I understand.
You can use the paneling. Others have used FRP attached to 1/4" plywood.
If I had a tank I would put a drain in it
You can get your panels from most of your RV supply places or Westmarine has a good selection (ahhh another link to put on my web site ). http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?...
I like this place as well: http://www.go-rv.com/coast/do/catalog/main?dealerId=1170
There was link to a place for that just recently anybody? only place I can think of is here: http://www.statewidealum.com/ but my experaince with them is nill to say the least.
You can check my web site for some other links.
Hope this helps.
Safe Riding,
Todd
Edited by maccwall 2005-08-17 4:09 PM
D. REDDISH
Reg. Aug 2005
Posted 2005-08-18 1:58 PM (#29350 - in reply to #29309)
TODD,
THANKS FOR YOUR FEED-BACK. YOUR WEB SITE IS VERY INFORMATIVE.
DAVID
maccwall
Reg. May 2004
Posted 2005-08-18 3:18 PM (#29353 - in reply to #29350)
500
You are most welcome David.
Safe Riding,
Todd
D. REDDISH
Reg. Aug 2005
Posted 2005-08-25 7:43 AM (#29589 - in reply to #29309)
TODD,
YOU ADVISED USING FRP ATTACHED TO 1/4" PLYWOOD. HOW THICK IS THE FRP AND WHERE CAN I PURCHASE IT.
DAVID
Posted 2005-08-25 8:05 AM (#29591 - in reply to #29589)
Originally written by D. REDDISH on 2005-08-25 6:43 AM
TODD,
DAVID
Lowes Homes stores sells the stuff in 4x8 sheets.  It's about 1/16 th inch thin.  About $30 per sheet.  I think it's used for shower and tub walls.
Home Depot, around here does not stock it.
