aluminum trailer repair
Last activity 2005-07-24 7:55 PM
2 replies, 4324 views
bellstarcreations
Reg. Jul 2005
Posted 2005-07-20 9:28 PM (#28340)
Subject: aluminum trailer repair
I am thinking of buying a trailer that has a leak in the roof. Can I repair that with caulk or will it need to be welded?? Thanks
Reg
Posted 2005-07-21 5:21 AM (#28349 - in reply to #28340)
Subject: RE: aluminum trailer repair
2000500100252525
Most minor leaks can be caulked, however since you don't yet own it I suggest you make it the seller's issue to get it fixed before you buy it.
If it is due to a STRUCTURAL problem that has been caused by... whatever, a fallen tree, unusual snow and ice load, etc., then you probably don't want to buy it, but it would likely need to be cut and welded.
The Mayor
Reg. Jul 2005
Posted 2005-07-24 7:55 PM (#28514 - in reply to #28340)
I have alot of experience (as a former Service Manager for a horse trailer dealership) w/ roof leak problems. It should be fairly obvious if there are structural problems, more often than not it is simply just a leak. I agree that you would be wise to make it the sellers responsibility, but there is a product called peel n seal that can be applied to the joints on the roof, heat (with a hair dryer if nothing else) as applied and it will solve the problem quickly and relatively inexpensively. There are different widths available, 4" will do the trick nicely. Good Luck!!
