Trailer squeeks
Last activity 2005-07-19 6:39 PM
10 replies, 6243 views
david
Reg. Apr 2004
Posted 2005-07-13 8:13 PM (#28029)
Subject: Trailer squeeks
I have an aluminum 3 horse goose neck. the brand is Soft Touch by Liberty made in Kansas.
It is 7 yrs old and has some major squeeks in it. Does anybody have any suggestions on what I can do to stop them ?
hav2ride
Posted 2005-07-13 8:15 PM (#28030 - in reply to #28029)
Subject: RE: Trailer squeeks
1000500100100
Are the brakes squeaking or the trailer?  I've never had the the actual trailer squeak.
david
Reg. Apr 2004
Posted 2005-07-13 8:17 PM (#28031 - in reply to #28029)
Its not the brakes. It just squeeks from underneath, and i wonder how it effects the horses.
Reg
Posted 2005-07-13 8:46 PM (#28032 - in reply to #28029)
2000500100252525
Try isolating it by getting in the trailer and jumping around.
It could be axle / suspension parts.
Have the ramp and doors all closed, it COULD be a ramp or door rubbing against it's frame opening. Also, check the condition of the rubber sealing strips around ramp and door edges, it might become obvious if you have metal to metal contact.
KelanSasu
Posted 2005-07-13 9:41 PM (#28035 - in reply to #28029)
Whether it squeaks empty or not might tell you a lot. Check the entire undercarriage: frame, floor, supports, etc. Use a VERY bright light while you're under there, like 100-150 watts in a reflector (NOT a flashlight!). Look for structural cracks and bent parts, bent floor runs, and so on. Check for loose bolts under there, too. A can of silicone spray can help as a "fault isolator" in some cases--just don't go wild with the stuff all at once or else it won't serve its purpose. KS.
Butch
Posted 2005-07-13 11:05 PM (#28037 - in reply to #28029)
Check out what the other posts recomend, I had a squeek one time and used a dab of grease on the ball, the squeek was gone.
hav2ride
Posted 2005-07-14 9:52 AM (#28048 - in reply to #28029)
1000500100100
Follow the recommendations given but, if you can't find it while not in motion, try hauling it and having someone in the trailer, sans horses!, to see if they can locate the noise.  The actual noise shouldn't bother the horses.  They get used to things very quickly if we let them.  I would be more concerned with a structural problem.
IFLY
Reg. Jul 2005
Posted 2005-07-14 10:25 AM (#28049 - in reply to #28048)
grease you gn ball
twogrey
Posted 2005-07-15 8:45 AM (#28103 - in reply to #28029)
Are you sure it's not the truck?
I also thought it was my GN trailer squeeking until recently watch some guys load my Chevy 3/4 ton truck with hay. With about 20 bales of hay in the bed, every time the guy stepped in with another bale, the truck squeeked!
The problem still isn't solved but at least I know it's not my new trailer!
gemm
Reg. Feb 2005
Posted 2005-07-15 8:58 PM (#28130 - in reply to #28029)
100100100100252525
I have to grease my gn ball occasionally or it makes a racket! It never seems to bother the horses, but my friends sure know when I'm comin' down the road!
horsin around
Reg. Jun 2005
Posted 2005-07-19 6:39 PM (#28280 - in reply to #28029)
100100100
I know this might sound dumb but I'd recommend getting in your trailer empty and having someone drive your trailer with you in it.  Just around the block is good enough.  Some friends and I were sitting around camp and decided to take a ride in each of our trailers to see and hear what the horses do while they're back there.  We noticed something in each trailer.  One had poor air flow, another had a terribly noisey middle gate and another a noisey removable tack.  It was a good learning experience.
Debbie
