Axle blocks for torsion axles???
Last activity 2025-02-24 5:38 PM
7 replies, 5157 views
kysunshine
Reg. Dec 2023
Posted 2024-09-22 8:20 AM (#185809)
Subject: Axle blocks for torsion axles???
We have a 2015 Hoosier 4H with torsion axles. We drive to a lot of campgrounds in NC and TN with sketchy turns and steep grades, our trailer has come much too close to the truck bed on more than one occasion and we would like to add blocks and raise it a few inches. Has anyone added blocks to torsion axles? *Calling our local trailer repair place too, just looking for input good and bad from those with experience.
tobruk
Posted 2024-09-22 8:04 PM (#185810 - in reply to #185809)
Subject: RE: Axle blocks for torsion axles???
Not a difficult process.  It's being done more and more as the new trucks as so tall.
Posted 2024-10-10 2:23 PM (#185817 - in reply to #185809)
I blocked my Sundowner trailer axles many years ago. Blocking the axles is simple IF the axles are bolted to the frame. Longer high grade bolts make it simple. If the axles are welded on, then they have to be cut off and rewelded with blocks.
Another solution is replacing the axles with the arm positioned below the axle center.
Cooter50
Reg. Oct 2024
Posted 2024-10-12 10:53 AM (#185818 - in reply to #185809)
I as well will likely have to do this. Bison 3HR LQ
Posted 2024-12-10 10:45 PM (#185844 - in reply to #185809)
Dexter makes a kit to lift torflex axles.
https://www.dexteraxle.com/product/2157/108/frame-spacer-kit
2Rocky
Reg. Dec 2024
Posted 2025-01-02 11:08 AM (#185854 - in reply to #185809)
Would folks who have done an axle block do it if the trailer was a 1995 model (30 years old) or opt for new axles with more aggressive torsion angle to raise the trailer instead?
I guess option C is new axles at same angle AND block to raise...
Posted 2025-01-22 2:07 AM (#185861 - in reply to #185854)
2Rocky - 2025-01-02 12:08 PM
As you're getting new axles, the block isn't needed.
Cooter50
Reg. Oct 2024
Posted 2025-02-24 5:38 PM (#185866 - in reply to #185809)
Got our blocks thru E-Trailer, installed myself and while is a dirty project not so bad to perform.
