2018 Shadow straight load two horse battery
Last activity 2024-07-29 12:33 PM
2 replies, 2343 views
Charlene0308
Reg. Jul 2024
Posted 2024-07-21 8:04 AM (#185776)
Subject: 2018 Shadow straight load two horse battery
2018 Shadow straight load two horse battery That has hardly been used and only 18 monyhs old, keeps dieing in the heat when i am not using trailer. Deka marine deep cycle cca 550 mca 675 130 minutes. This powers emergency brakes, fans, and lights when trailer not hooked to vehicle. Should I be disconnecting battery when I am not using trailer to save battery and/or should I get different battery? I know nothing about batteries or electrical in trailers so any advise is appreciated.
RTSmith
Posted 2024-07-24 9:17 AM (#185778 - in reply to #185776)
Subject: RE: 2018 Shadow straight load two horse battery
While 12-24 months is a typical lifespan for a deep cycle battery, yes- a disconnect switch or manual disconnection can take care of a parasitic drain. What you are using is the proper battery, it can be as much age rather than usage. And if they ever sit discharged for a while , they don't seem to recover very well.
HOUSE
Reg. Oct 2008
Posted 2024-07-29 12:33 PM (#185780 - in reply to #185776)
Subject: RE: safty hitch system
 I would put a solar charger on it, make sure that it has a built in charge controller, it should last 3-5 years, at least that is what mine do.
