replace brake light (Circle J trailer)
Last activity 2023-11-21 6:25 AM
2 replies, 3888 views
spavich
Reg. Nov 2023
Posted 2023-11-20 11:39 AM (#185653)
Subject: replace brake light (Circle J trailer)
I need to replace a brake light on an older Circle J straight load trailer. How to I remove/access the light? It looks like it is riveted on the trailer. Any help would be appreciated, thanks.
(trailer.jpg)
Attachments trailer.jpg (95KB - 0 downloads)
cajunmuleman
Reg. Oct 2011
Posted 2023-11-21 4:53 AM (#185654 - in reply to #185653)
Subject: RE: replace brake light (Circle J trailer)
Pop out the ring around the perimeter of the lens.  It has a raise spot to assist you in getting a screwdriver behind it
DLR
Reg. Jul 2004
Posted 2023-11-21 6:25 AM (#185655 - in reply to #185653)
If you want to replace the entire light, drill out the 3 pop rivets.   These type of lights are readly available.  If just to replace the bulb, popout the retaining ring that holds the lens and the bulb is behind the lens.
