Clicking noise in Lunde Lift control box
Last activity 2023-06-26 9:52 AM
2 replies, 2073 views
Idahocowgirl1954
Reg. Jun 2023
Posted 2023-06-23 1:52 PM (#185584)
Subject: Clicking noise in Lunde Lift control box
Hi. I have a Lunde Lift on my living quarters trailer. I have been having problems getting it to lower the leg to unhook. The co tell box will run for a short time then click off. I have to let it sit for a minute until it clicks again then it will work
Any ideas as to what is causing this ?
Thanks In advance
RTSmith
Posted 2023-06-26 9:40 AM (#185585 - in reply to #185584)
Subject: RE: Clicking noise in Lunde Lift control box
500100100100
Likely a power issue. Check battery voltage and condition. Remember RV batteries generally have a 1-2 year lifespan. Otherwise a dirty or corroded connection somewhere likely at a higher voltage point like at the solenoid or relay.
Posted 2023-06-26 9:52 AM (#185586 - in reply to #185584)
The "click" and the time between operation sounds like a thermal overload operating. AS posted before by RT Smith... check the batteries. Low voltage from a weak battery will result in high current draw. Also, if the motor is highly loaded, high current will happen too.
I suggest you take the trailer to a competent shop for repair.
